Old 05-22-2015, 05:28 PM   #1
JnJ in TX
To Valve or not to valve
We just bought our 1st RV. It is a 2012 Salem Hemisphere 246RLBS. The previous owner was not very RV savvy and unsure about some of the "things" on the RV. There is a valve on a white hose that appears to come from the water heater. As you can see from the photo, it is not the bypass valve. I did not have any luck with the owners manual. Thanks in advance!
Name:	Water Connections.jpg
JoandJames is offline   Reply With Quote
Old 05-22-2015, 05:43 PM   #2
captnrick3's Avatar
Could it be a water tank fill, used to fill your tank while hooked up to city water? I can't quite read the label but that is my take.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 05-22-2015, 06:12 PM   #3
Firefighter969's Avatar
X2 on fresh water tank fill
2000 F250 Superduty CC LB 7.3 4x4
2013 344QB Wildcat
Nights camped 2014 ( 15)
Nights Camped 2015 ( 4 )
Firefighter969 is offline   Reply With Quote
Old 05-22-2015, 08:25 PM   #4
JnJ in TX
The label above this hose is "Fresh Water Connection". It relates to the female hose connection just above the label. It's a bit confusing. The city water connection on the left is below the label. Not a lot of consistency here. I have a Suburban water heater. Is the only way to drain it is to take out the anode? I took this one out and it was 99% gone. Anyway, I guess I could open the valve and see what happens!
Old 05-22-2015, 10:05 PM   #5
captnrick3's Avatar
The fact that you took out the anode rod spells "good show"! On the Suburban's I've had that is the only way to fully drain. The rod will usually consume itself in 12 to 18 months depending how much you are connected to shore power (which creates electrolysis). Just plan on replacing and that heater will last longer than the rest of the rig. Be sure to flush out the tank as good as possible to get all the debris out, there will be plenty. Usually whitens my whole driveway when I flush one out. Local RV store should have a flush out tool that works very well . http://www.amazon.com/Camco-11691-Wa...+flushing+tool
2015 Legacy 340KP
2012 Wrangler Sport
Old 05-22-2015, 10:50 PM   #6
Just a member
kandl's Avatar
That's an interesting setup but I'm thinking the same as was previously indicated - a shut off for the fresh water supply. Have you attempted to trace the plumbing? The label above the female connector appears to be the standard, canned precaution re sanitizing and filling fresh water tanks.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 05-23-2015, 07:40 AM   #7
Mr. Dan's Avatar
Yes, you'll have to trace the plumbing on the backside of those panels. Otherwise, our guesses here will range from plumbing to drain the fresh water tank, plumbing to drain the water heater, plumbing to add anti-freeze for winterizing, plumbing to dispense cranberry juice to combat kidney stones. As kandl says, "That's an interesting setup...." My translation of that is "I've never seen anything like that (as in - the previous owner did something clever or crazy)". Get behind those panels or come in from the bottom to see the intended purpose.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 05-23-2015, 10:49 AM   #8
jk510's Avatar
Silly question, but what happens if you open the valve?
It looks like it was factory installed. Could it be a drain? Though it seems too high to be a low point drain.
Joel K
Southeast AZ
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
Old 05-23-2015, 02:14 PM   #9
2007 WildCat 32QBBS
05CrewDually's Avatar
I believe that is a water heater by - pass for winterizing. You don't want to waste putting gallons of antifreeze in your water heater.
Is this what you're referring to:
Name:	2015-05-23 15.16.10.png
05CrewDually is offline   Reply With Quote
Old 05-23-2015, 04:48 PM   #10
Send a message via MSN to Tiggerdad
Welcome to the forum. I see your city and state. Same as mine. Live past Junior High in L.C.-M.
Traveling now. Will be back in town towards the end of the week. I will contact you and willing to help you learn the "ropes."
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
