If you weighed 250 lbs, would you trust a ladder that has a rating of 175 lbs, to use on a daily basis??? Would you continually go up and down that ladder dozens of times a day, hoping it would not give way.
Yeah, the hitch probably has some "giggle room", but at 600 lbs your already 10% over it's rating. Also, it's not just the hitch, but you also must consider the frame where the hitch is bolted. Some are just extensions welded onto the regular frame, and may not be rated over the 5000 lb rating.
Best solution would be to get a class 4 rated hitch. Their usually rated for 10,000 lbs (have one on my class c). You just have to be sure the frame rails are strong enough to take the extra strain of a 5600 lb toad.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
