Old 08-12-2015, 03:20 PM   #1
Toilet not holding water
Dometic 310, 2nd season for it. Toilet started not holding water in the bottom of the bowl. Takes an hour or 2 for it to seep out. Should I be using Vaseline or some other type of lube on the rubber gasket in the bottom of the bowl?
PS - as typing this, just happened to think maybe it's something like a piece of TP wedged in the groove of the gasket, will check that, but open for any other ideas. Thanks !
steveh326 is offline   Reply With Quote
Old 08-12-2015, 03:22 PM   #2
TURBS's Avatar
Yes clean around the gasket sealing area for debris.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-12-2015, 03:24 PM   #3
brookstone345sa's Avatar
I put rubber gloves on and use vegetable oil on the rubber seal
brookstone345sa is offline   Reply With Quote
Old 08-12-2015, 03:37 PM   #4
Try putting near boiling water in the bowl and let cool. Might seal the gasket.
Westiedog3 is offline   Reply With Quote
Old 08-12-2015, 03:59 PM   #5
Would not do that as the flapper is plastic and it might warp or crack the bowl.
Old 08-12-2015, 10:40 PM   #6
Following. I'd like to know what other folks have to say. Our TT is only a year old but i want to be prepared.
2014 Wildwood x-lite 185br
towed by 2013 Ram 1500
laurarice26 is offline   Reply With Quote
Old 08-12-2015, 11:00 PM   #7
Evereddie's Avatar
It's a lime buildup on the rubber seal and the surface it seals with, the dome shaped flapper that moves with the foot pedal. Take a kitchen scouring pad (don't use anything metal like an SOS pad) or scour side of a sponge and very lightly rub both surfaces. You can use a little vinegar or Lime-A-Way, or CLR. For me just a very light rub with the scour side of the kitchen sponge is all it takes.
From what I could feel on mine the first time I cleaned it, the buildup was more so on the bottom side of the rubber gasket than the plastic flapper that moves.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 08-12-2015, 11:49 PM   #8
Crockett's Avatar
that 310 bowl seal just pops out. careful you dont lose it down the toilet. it would prolly clog and it costs about way too much to replace. list price was about 45 bucks when they first came out. anyway, you could then clean it and then pop it back in with the valve closed. um...if you really wanted to clean it good
Crockett is offline   Reply With Quote
Old 08-13-2015, 11:55 AM   #9
bubbles's Avatar
Actually, this is a recommended procedure in my 310 manual for when bowl will not hold water. Bowl of 310 is ceramic.
Old 08-13-2015, 12:09 PM   #10
Since we use olive oil for cooking I use it stay away from petroleum based products they will break the rubber seals down.
Myrle is offline   Reply With Quote
water
