03-03-2016, 08:28 PM
JudiVan n Gus
Toilet Paper in the RV
So My wife and I are in a discussion about the use of TP in the RV. She thinks that we can use any TP we want and I say that we have to use RV TP only!
So can you all tell me which one we should use and why? or is there even an issue here? We are new to RVing, our unit is in the driveway but we have not used it as of yet. We were going to go out next wknd but rain is in the forcast for CA, (can you believe it) Rain in CA.... We need it... Please let us know about the TP.
03-03-2016, 08:34 PM
Mddle of the Rd Extremist
After almost a year of buying "RV" toilet paper, we found out (by way of this forum) that there are several commercial (read cheaper) brands that will work just fine. We've been using Angel Soft exclusively for the past two years without any problems whatsoever......enjoy the go
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
03-03-2016, 08:38 PM
Who Dares, Wins
I use the Charmin soft.. Same as we use at home.
Use the glass bottle technique to. See if your good. Put two or three sheets in the bottle, fill with water and shake a bunch of times. See how or if it breaks down. If so your golden.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
03-03-2016, 08:45 PM
If the label on the TP says "Septic Safe" it should be acceptable for RV use. They are supposed to sorta dissolve in water (as Doc73 described).
BIRDS AREN’T REAL
03-03-2016, 08:49 PM
We use Scott 1 ply with no issue. My DW is not a fan. I just found a rapid dissolving version on the Scott website and supposedly is available at Walmart.
Joe and Diane Buskirk
2015 Chevrolet Silverado 3500HD Duramax Diesel 4x4 SWD
2015 360IBL Coachmen 5th Wheel
"Camping is not just a past time it is my relaxing way of life"
03-03-2016, 09:14 PM
JudiVan n Gus
Thanks everyone
Thanks everyone for all of your responses, This has been very helpful to us and I look forward to learning more from this FROG forum site...
03-03-2016, 09:21 PM
As stated above any septic safe TP is fine. I've been using Angel soft since 2011 with no issues. Just remember to put extra water in the bowl when having a bowel movement. Water is the key to black tank management. Don't let your black tank be dry. Empty when 2/3 or more full (or fill with water to 2/3 before dumping), flush tank using black tank flush or a tank wand, rinse and repeat. When flushed and empty leave a few gallons of water in the bottom of the tank to prevent the dreaded stone mountain from forming. I recommend using the geo method for tank management.
2014 Sabre 34REQS-6
03-03-2016, 09:34 PM
Been using Scott for 8 years with no problems along with chemical treatments during outings and a good tank flushing when done.
2014 Prime Time Sanibel 3250
03-03-2016, 10:04 PM
Like mentioned already. If your not certain, take a quart jar with lid. Fill about 3/4 full with water. Add 2-3 pieces of tp and shake. If it breaks up you can use it. If its still solid, stay away from it.
03-03-2016, 10:24 PM
Of coarse youtube to the rescue...
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
03-03-2016, 10:32 PM
I used to use regular TP and had tons of issues with tank dumps so I went back to rv TP and have not had an issue since. Might have been the design of the rv black tank though.
Eastlake, Ohio
2013 F-350 Turbo Diesel
2016 Heritage Glen 368rlbh
03-04-2016, 12:20 AM
Always Learning
We did a science fair experiment and concluded that you can use whatever feels best on your bum. Just use plenty of water!
Been fulltiming for 9 months now and 50-100 nights in the years prior- no issues.
03-04-2016, 12:52 AM
Interesting. I always used Charmin at the house and Angel soft in the trailer. I might just switch to Charmin for both.
2014 Sabre 34REQS-6
03-04-2016, 05:55 AM
Gold Miner At Heart
The only time we really had a bad clog we were using Charmin. However that's been about 18 years ago and I can't remember which Charmin we were using. After that we ONLY use RV paper. One really bad clog up and you never make the same mistake again. I will also say that our two girls were young then so that probably was a major contributing factor.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
03-04-2016, 06:21 AM
We have found that we can use regular TP but honestly, when I dump, I can see the difference between regular and RV TP. The RV TP dissolves more thoroughly.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
03-04-2016, 06:30 AM
World Wide Wanderer
Charmin.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
03-04-2016, 10:09 AM
Been using the Kirkland brand from Costco for 5 plus years. No issues.
2016 FR3 30DS and a
97 Jeep Wrangler that follows me to close
03-04-2016, 01:04 PM
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
We've been using Scottt Rapid Dissolving which is readily available at Wally World. It's comfortable for my wife to use also. But if you use any old tp, you're going to run into trouble with it not breaking down in the tank, on the sensors, and the gate valve. If you can't find it, do what Doc73 did with the glass jar. Just make sure you don't use any old tp without putting it to the test, unless you like black tank problems.
03-04-2016, 01:24 PM
03-04-2016, 01:27 PM
We have some friends who use that system with the "tower" next to the toilet. I always make sure I've pee'd before we go visit them. Nasty if you ask me.
