Old 03-03-2016, 07:28 PM   #1
JudiVan n Gus
judivan's Avatar
Question Toilet Paper in the RV
So My wife and I are in a discussion about the use of TP in the RV. She thinks that we can use any TP we want and I say that we have to use RV TP only!
So can you all tell me which one we should use and why? or is there even an issue here? We are new to RVing, our unit is in the driveway but we have not used it as of yet. We were going to go out next wknd but rain is in the forcast for CA, (can you believe it) Rain in CA.... We need it... Please let us know about the TP.
judivan is offline   Reply With Quote
Old 03-03-2016, 07:34 PM   #2
Mddle of the Rd Extremist
MeepMeep's Avatar
After almost a year of buying "RV" toilet paper, we found out (by way of this forum) that there are several commercial (read cheaper) brands that will work just fine. We've been using Angel Soft exclusively for the past two years without any problems whatsoever......enjoy the go
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 03-03-2016, 07:38 PM   #3
Who Dares, Wins
doc73's Avatar
I use the Charmin soft.. Same as we use at home.
Use the glass bottle technique to. See if your good. Put two or three sheets in the bottle, fill with water and shake a bunch of times. See how or if it breaks down. If so your golden.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 03-03-2016, 07:45 PM   #4
Usually Confused Member
emm-dee's Avatar
If the label on the TP says "Septic Safe" it should be acceptable for RV use. They are supposed to sorta dissolve in water (as Doc73 described).
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 03-03-2016, 07:49 PM   #5
buskirk21921's Avatar
We use Scott 1 ply with no issue. My DW is not a fan. I just found a rapid dissolving version on the Scott website and supposedly is available at Walmart.
Joe and Diane Buskirk
2015 Chevrolet Silverado 3500HD Duramax Diesel 4x4 SWD
2015 360IBL Coachmen 5th Wheel
"Camping is not just a past time it is my relaxing way of life"
buskirk21921 is offline   Reply With Quote
Old 03-03-2016, 08:14 PM   #6
JudiVan n Gus
judivan's Avatar
Thanks everyone
Thanks everyone for all of your responses, This has been very helpful to us and I look forward to learning more from this FROG forum site...
Old 03-03-2016, 08:21 PM   #7
asquared's Avatar
As stated above any septic safe TP is fine. I've been using Angel soft since 2011 with no issues. Just remember to put extra water in the bowl when having a bowel movement. Water is the key to black tank management. Don't let your black tank be dry. Empty when 2/3 or more full (or fill with water to 2/3 before dumping), flush tank using black tank flush or a tank wand, rinse and repeat. When flushed and empty leave a few gallons of water in the bottom of the tank to prevent the dreaded stone mountain from forming. I recommend using the geo method for tank management.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 03-03-2016, 08:34 PM   #8
rracer5's Avatar
Been using Scott for 8 years with no problems along with chemical treatments during outings and a good tank flushing when done.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 03-03-2016, 09:04 PM   #9
Like mentioned already. If your not certain, take a quart jar with lid. Fill about 3/4 full with water. Add 2-3 pieces of tp and shake. If it breaks up you can use it. If its still solid, stay away from it.
Grisham91402 is offline   Reply With Quote
Old 03-03-2016, 09:24 PM   #10
CWSWine's Avatar
Of coarse youtube to the rescue...
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
