Old 05-09-2012, 07:47 AM   #1
Tongue jack height problem
With my tongue jack all the way down it is barely enough to pull the truck out from under the hitch. I use a short piece of 2x6 under it at the campground. At home I put two cement blocks under it and then I don't have to extend it as much. I really don't want to have to carry cement blocks camping with me and am wondering if anyone else has this problem and how you are handling it?
comfun1 is offline   Reply With Quote
Old 05-09-2012, 07:51 AM   #2
I carry a couple of short wooden blocks, 4 inches x 6 inches, Poplar wood, gotten from a local pallet shop since they were scrap. Poplar wood is light, but handles the tongue weight just fine. That was for my manual jack. Last year I installed a Husky electric jack, and it has an adjustable length foot, which adds up to 8 inches or so, when needed.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 05-09-2012, 08:06 AM   #3
Herk7769's Avatar
I carry several 1x10 pressure treated boards cut 12 inches long from an 8 foot plank (8 pieces).
I use them to level the camper left to right and in the olden travel trailer days I also carried a 6x6x6 block of wood that I put on top of the 1x10 to put under the front jack.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-09-2012, 08:20 AM   #4
Aha! So the old wooden block method is still king. This after I bought my fancy little bag of plastic leggo leveling blocks. That's what I get for not asking first.
Old 05-09-2012, 08:33 AM   #5
Thurman's Avatar
I also was using blocks of wood, sometimes forgetting and leaving the camp area without them. Then I found the "Flip Jack" (google it). I put one on my unit with an electric tongue jack and no more wooden blocks. I liked this Flip Jack so much I bought another and installed it on my 18 ft. cargo trailer with a manual jack.
Thurman is offline   Reply With Quote
Old 05-09-2012, 08:39 AM   #6
I have the Flip Jack also and really like how well it works.
Len & Cheri is offline   Reply With Quote
Old 05-09-2012, 08:51 AM   #7
TURBS's Avatar
They also make a jack foot extension
here. trailer jack foot extension - Google Search
Old 05-09-2012, 11:59 AM   #8
Herk7769's Avatar
Originally Posted by comfun1 View Post
Aha! So the old wooden block method is still king. This after I bought my fancy little bag of plastic Lego leveling blocks. That's what I get for not asking first.
I have two bags of the Lego blocks and I have used them when on cement pads. Advantage is they are lightweight and neat looking.
Disadvantages I found are that on turf or asphalt they sink into the ground and can be near impossible to remove and hard to clean.
On gravel they get broken and cut by the sharp edges on the stone.
Wood blocks work on everything.
Old 05-09-2012, 08:12 PM   #9
I cut out square pieces of diamond plate and put them down on the bottom of the lego blocks for the some of the reasons you listed.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 05-09-2012, 09:57 PM   #10
bikendan's Avatar
or buy an electric tongue jack, with an adjustable foot, like the UF 3500.
got mine off of Ebay for around $100 and it's been working great for 4 years.
Old 05-09-2012, 10:08 PM   #11
chucker25's Avatar
Comfun1 - when the trailer is hooked up normally does it sit relatively level? Just wondering if the hitch (ball to ground height) is excessively high? If so, maybe the problem isn't the length of the jack tube but the distance it has to travel ??
2013 Rockwood A128S
Ford Ranger
chucker25 is offline   Reply With Quote
Old 05-09-2012, 10:39 PM   #12
Herk7769's Avatar
Great idea. Gonna do that.
Way less weight than the planks and I can use my Lego blocks more often.
Old 07-28-2014, 02:30 PM   #13
e have been out in our Flagstaff 5th wheel once and when I went to disconnect from my truck the jacks came up about 2 inches and stopped. After investigation , the bolt for the connecting bar had sheered off. Tried a new bolt and same thing happened . Checked the top of the left jack and the gear was free turning , no longer attached to the lifting rod. The dealer told me I had over extended the jack :-( can someone tell me how you determine the maximum depth you can use for the jacks ? Dave
datadave12 is offline   Reply With Quote
Old 08-01-2014, 04:20 PM   #14
Stg1's Avatar
OP- They manufacture a cone shaped stand that has a hole in the top for the jack tube to sit in. It's made of tough plastic and is designed for the tongue jack. The only drawback is you have to remove the foot pad on the jack. If you don't want to do that, then use wood or the lego blocks to shorten the travel distance for the jack.
Steve and Marlene and 2 Furry Kids. LB (Maltese) Rocky (Border Terrier)
2013 Coachmen Catalina 25RKS 2006 Nissan Titan Crew Cab
Stg1 is offline   Reply With Quote
Old 08-01-2014, 08:12 PM   #15
The yellow cone is sturdy enough to do the job. Light weight yet strong. Stores easy. Pretty sure I got it at. CW or Walmart.
Wouldn't be with out it.
Sent from my iPad using Forest River Forum
Poper
Poper is offline   Reply With Quote
Old 08-05-2014, 08:24 PM   #16
Installed a Fastway Flip foot this weekend. Works great and adds several inches to jack height. Folds auto when you raise jack. $42.60, including shipping.
hydrope is offline   Reply With Quote
