Originally Posted by Smiletwice
I started by asking the dealer when we upgraded our trailer. He looked at me like I was an alien and said my pickup could pull anything in the showroom up to 20,000 lbs. Don't worry about the tow capacity. That's propaganda! OK...I exaggerate.
In the alphabet game regarding weights and trucks, there is another term, GCWR or sometimes GCVWR. (which you did mention).
This is the total weight of truck and trailer, regardless of tongue weight. It's determined by the manufacturer and is controlled by HP, Torque, Transmission (durability), rear end ratio, and most importantly, brake efficiency.
Salesmen often ignore some important safety and durability factors in their zeal to sell vehicles. Yes, your truck may be able to tow the space shuttle but will it do so up an average highway grade? Will you be able to stop it without relying totally on the trailer brakes? Will your transmission and differential carry the load, mile after mile. Is the cooling system for both engine and transmission rated for the GCWR you are planning on driving down the road with?
Might want to look at the owners manual and see what it says and place more credibility in that than what a Salesman tells you.
FWIW, that "Propaganda" is put together by the people who've actually tested the vehicles under all the conditions we will eventually see and have set these combined vehicle weight limits for a reason.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
