Old 11-19-2019, 08:53 AM   #1
Tore corner of trailer with tail sway
Yep the tail sway got me in parking lot post. Called progressive insurance and there coming out. 2012 evergreen 27ftr and corner pulled out about 22 inches tall and back about 6 inches in. Waiting for adjuster pTryimg to figure out whether to pull corner back in myself which is about two inches out and cover with eternabond or let shop do it. Just guessing trailer probably worth 9k. Looks ok on rest of trailer ,but not perfect. Fading from Florida sun and decals cracked. Should I pocket the money and fix myself for 50 dollars or send to rv shop. Any suggestions. Thanks
Planning on keeping it for 5 more years.
ID:	219435   Click image for larger version
ID:	219436   Click image for larger version
Tampajohn is offline   Reply With Quote
Old 11-19-2019, 09:12 AM   #2
If "Tail Sway in a Parking lot" got you,your Speed was way to Fast! Tail Swing is more likely! If Decals are peeling and the trailer is Sun faded just a Patch job seems sufficient. I doubt they will pay to make it like New. Youroo!!
Old 11-19-2019, 09:17 AM   #3
KyDan's Avatar
That age and keeping it that much longer.... I'd take the money and patch it myself-- As long as you're sure your patch is keeping the water out!!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 11-19-2019, 09:22 AM   #4
Flybob's Avatar
You might try waterproof construction glue in between the separated sections then clamp for several days. Add new screws to the edge then add new edge trim with a good caulk/glue.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-19-2019, 10:16 AM   #5
My mistake, Using term sway, it was tail swing
Pulling with an F250 and a Hensley Hitch, there is no sway at all. Trailer is only 5100 lbs dry weight. I do not even know the trailer is back there.
We are driving a Ford F250 Gasser and pulling a Evergreen G269FK. We also have a Cairn Terrier. 2 Champion Generators. This year, planning on 6 months in our Evergreen visiting, California, Michigan, and Ohio. We live in Florida. Grandkids, and dog are why we camp. Also have a Hensley Hitch which that eliminates all sway. Pricey, but worth it.
Old 11-19-2019, 10:24 AM   #6
Thanks much for repiies,
Kind of my thoughts also of me doing my own repair. Waterproof caulking and eternabond does wonders. Curious to see what the insurance company is going to do. I will keep you posted, one step at a time. I also wonder if I got nailed at the storage lot. We packed up and threw some food in and took off the Tropical Palms close to Disney. Kind of interested to check units in storage area for dents or scratches. I live in Sun City Florida and a bunch of old people including me. LOL The corner trim is so wrinkled, I am curious if anyone knows where I could but a piece of it. I also am not certain how I get to the screws. Any help appreciated.
Old 11-19-2019, 10:24 AM   #7
Evidently so
If you file a claim, pocket the cash and cobble together a patch job you do realize your insurance rates are almost certain to go up, maybe substantially, for not only the trailer but any of your other vehicles also?
If I was going to go down that road I think I would just find a competent place and let them do the complete repair which may mean re skinning the rear wall.
Feel Swift is offline   Reply With Quote
Old 11-19-2019, 10:36 AM   #8
Thanks. I have accident forgiveness. Hope that included rv. Already called them and hope payout is more than increase in rates.
Old 11-19-2019, 10:45 AM   #9
You might want to look into that accident forgiveness. Look on your policy and review your discounts. What they will do is not raise your rates because of the "accident forgiveness", but at next renewal you'll lose your "accident free" and "safe driver" discounts. It's all a cleverly designed shell game. And if you have Progressive and some others, just one speeding ticket or other moving violation in the last 3 years will void "Accident forgiveness". Now you have a rate increase, and lose "discounts". It can get expensive quickly.
You're not going to file a claim when you're at fault that does not cost you money in the long run.
Old 11-19-2019, 11:42 AM   #10
rollscanardly's Avatar
Dicor Seal-tite corner tape...
I used this tape when I rebuilt my camper. See post # 161 for pics...
Insane 1999 Wildwood repair....pic heavy!
https://www.amazon.com/Dicor-CS112B-.../dp/B0778KMN74
Good stuff!
Rich
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2004 Dodge Ram 2500 Quad cab, 5.7L Hemi, 4.10 gears.
rollscanardly is offline   Reply With Quote
Old 11-19-2019, 01:41 PM   #11
SailorSam20500's Avatar
Another option if you decide to do the work yourself. You mentioned using Eternabond. Because the repair will be down low and in plain sight, I would consider using the FlexSeal clear tape.
I used some to seal a leak in the gutters on my house. Tape feels like a thick vinyl and bonds extremely well. While it has only been on for a few months now, we have had both hot weather and now a lot of snow... Bond is holding water tight.
I'd expect the FlexSeal to be a lot less noticeable.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is online now   Reply With Quote
Old 11-19-2019, 01:46 PM   #12
Rear damage
I did the same almost, slid the left side against the cement wall in the driveway and did not file as the repair was the same as the deductible. Gotta watch the deductibles.
SQROOT is offline   Reply With Quote
Old 11-19-2019, 02:22 PM   #13
RV salvage yards
From an RV "junkyard." Here are some in Florida, from Google. There are others if these are not close or do not have the parts.
Waltrip Used RV Sales formerly Bob's Used RV parts
https://www.facebook.com/waltripusedrv/
Brandon Auto Salvage
http://www.brandonauto.com/
Loetscher Auto Parts
http://www.loetscherauto.com/
Creative Coach Collison Repair
Creative Coach Collision Repair and Design Center in Lakeland, FL is an interior design company for motorhomes.
Conibear RV Center
http://conibearrvcenter.com/
These sites have lists by state, too
Florida RV Salvage - used RV parts in Florida (lists 20)
Motorhome salvage lots in central Florida
https://rtrvg.com/blog/2017/07/22/us...ards-by-state/
(lists 19)
RV Salvage or Junk Yard in Orlando, Fl??
Discussion right here on FRF
Larry
Larry-NC is online now   Reply With Quote
Old 11-19-2019, 03:33 PM   #14
CaptnJohn's Avatar
Do not think you are the only one! Most hide the fact!
WELCOME TO THE CLUB!
Name:	Tail Swingers Club.jpg
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 11-19-2019, 04:26 PM   #15
You guys are a encyclopedia of knowledge. Last ticket was over 20 years ago. I drove a school bus cause wife said I needed something to do in retirement and quite aware of tail swing. Tail swingers club funny. All ready called progressive. I might be sorry. To late now let's see what they do. Thanks all . Rv salvage yards very informative
I live in Tampa. Adjuster coming out Friday. Thanks again for all comments.
Old 11-19-2019, 05:00 PM   #16
Retired Old Fart
dward51's Avatar
I can't tell from the photo, but did it split the wood or just pull it away? If it just pulled it away it should not be that hard to fix (but let insurance get their photos first - and protect from weather while you wait).
You likely just need to pull that center rub section out of the trim then you can access the fasteners for the trim. It is likely just going up to the top of that section and not along the roof. Then reattach the pulled away wood (pull those staples out) and install a weather resistant foil to seal along the back and side panel edges (you will likely need to cut it down so it can be covered by the trim, but it will form an extra weather barrier under the trim. Install new trim, new center piece and seal around the edges. Should look like new.
If you have ever worked on a rub rail on the side of a boat, that is how the center section of that trim is installed. It covers the trim fasteners, and the under section should slightly wrap around the corner.
Edit -------------------
I did not notice the tear in the 2nd picture the first time I looked at it (around the area of the ".com" in the dealer name). But it looks like you should be able to patch that with 2 part epoxy from the rear and along the tear and it will be both water tight and not visible.
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 11-19-2019, 05:16 PM   #17
Split the wood.
It split the plywood. Separated the layers and also tore the outside of fiberglass about 6 inches. What I was thinking was put a piece of 2 x 4 behind and assemble layer of plywood with construction glue. Use screws to get back together and cover the patch job with black eternabond. The tan trailer has black trim all around it. Eternabond will make it completely waterproof. Wife chuckled and said This is not a provost. Lol. Paid 13k for it. Pulled over 80k miles. Took care of it mechanically but Florida sun beat it to death. Put ZEP floor polish to get some shine. 5 more years will provide 50k more miles. That will move me close to age 80. Probably slow down bit then ,but now play tennis daily. Sell it then for what ever i can get. Lol
Old 11-19-2019, 05:18 PM   #18
Did a similar oops. Start tearing it apart, trim and all the screws etc are readily available at most RV stores. You might be surprised at what you can accomplish by using this forum and google and just going to body shops etc.
Good luck.
2017 FR3 28 DS
cariboo camper is offline   Reply With Quote
Old 11-19-2019, 06:07 PM   #19
Been there, Done that...
Did the same thing at a gas pump- made a very good repair myself. I googled RV repairs and found a youtube video that spelled it out including parts list. I cleaned up the "wound" by removing the ruined trim piece and filled with caulk. Then I got that roofing tape- it's about 8 inches wide and super sticky and silver. I cut a piece to fit and used a credit card to press it on hard and smush out air bubbles. THEN - as per the video - i took a white vinyl fence post, split it lengthwise and cut to fit and carefully screwed it over top of the silver tape; caulked the edges, and about 3 hours later, I had a very good repair. My RV is an '03 Jayco, so- it's waterproof and not bad looking, but didn't want to spend the money for the shop repair. Plus my camper angled in, yours looks straight up and down, much easier! Hey, if I can do it...anyone can!
Dela is offline   Reply With Quote
Old 11-19-2019, 06:24 PM   #20
Tom48's Avatar
On of my camping buddies did about that to a brand new Grand Design 5er. Insurance paid $14000. A tad bit better than the day it happened and we pulled it together with aid of ratchet straps and two or three strong men, pinned with the judicious use of three inch drywall screws.
Tom48 is offline   Reply With Quote
sway, trailer
