Old 01-12-2016, 08:36 PM   #91
Originally Posted by JeffandLori View Post
Thanks, Airdale. I recognize the manufacturer is not morally- or especially emotionally, attached to the trailer as I am. However, in terms of the issue at hand, please recognize I am new to RVing and having just purchased my first camper you can only imagine my surprise to find legions of report of tire failure resulting in trailer damage with less than 1,000 miles.
When doing the math, I have four tires rated at 2,100 each for a total of 8,400. With an empty trailer weight of 6,950, 350 pounds worth of water and roughly 300 pounds worth of "stuff", that puts me at a total weight of 7,600. Minus 800 pounds for tongue weight and we are at 6,800 pounds. Certainly well below the 8,400 rating but that does not change the fact that multiple forums seem to decry original equipment tires. Individual reports of multiple failures on the same trip and a dearth of "I've been running years on my OEM tires." leads me to believe the immediate need is new tires over TPMS.
What little research I have done so far also seems to lean toward Goodyear Maxxis over Marathon.
Blackhat: thanks. Not sure what happened there. I tried copy-paste, editing the URL, etc. to no avail. Recent links worked. I appreciate the extra effort there.
QUESTION: As my rims are 15" and I'm not looking to replace them, if I were able to find load range E tires in the correct size, is it worth it? Likely making 6-10 short trips per year and hopefully one longer one of around 1,000 - 1,200 miles round trip.
Thanks all for your patience as I figure this out and try to learn from the experiences of you all.
Agin there are NO Goodyear Maxxis! Youroo!!
Old 01-12-2016, 08:51 PM   #92
Originally Posted by emm-dee View Post
Maxxis makes the M8008 tire in load range E.
Thanks. That is most helpful. If they have it in a 225/75R15 that sounds good. A little higher can't hurt. Not like I am worried about ride quality back there, eh?
JeffandLori is offline   Reply With Quote
Old 01-12-2016, 08:53 PM   #93
Ahh, my bad. I misunderstood some of the postings. Thank you for clearing that up. Probably saved me some dumb looks at the tire shop.
(See disclaimer about being new. lol)
Old 01-12-2016, 08:54 PM   #94
Usually Confused Member
emm-dee's Avatar
Here's the link showing the E-load in your size. Ignore the price...that's retail and everyplace sells them for much less.
Maxxis M8008 Radial Tire | Maxxis® TiresÂ*
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 01-12-2016, 09:34 PM   #95
hmm, closest dealer is about two hours away. Appears I can get them for $133 each with free shipping. Will need to check what install and balance would run.
Old 01-12-2016, 09:44 PM   #96
emm-dee's Avatar
I don't think you have to go to a listed Maxxis dealer. The shop I deal with sells a lot of Maxxis tires but is not a listed dealer. They, like most independent tire dealers, can order just about any brand they want. Check with your closest independent and see if they can order them.
Old 01-13-2016, 02:21 AM   #97
Rivnut
Rivnut's Avatar
Tow max tires. I had 11k miles 2 years old. Checked each day. Week be4 trip i I see funny bulge on one. Further check two aware bulged, one is cracked severely. Chase down Tow max warranty lady sunning herself in Palm beach gardens, she gives me $144 on two tires, all checked by local dealer. Best I could
Get, just put 4 Maxxis on and good to go.
Rivnut is offline   Reply With Quote
Old 01-13-2016, 05:39 PM   #98
Blackhat6mike's Avatar
Just so I don't unintentionally mislead anyone with my "think before you type" errors, there ARE NO GOODYEAR MAXXIS TIRES! I made a boo boo.
Maxxis are Maxxis.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 01-13-2016, 06:10 PM   #99
emm-dee's Avatar
I think what you intended originally is Goodyear/Maxxis, with the / meaning and or or. Sometimes it's hard to say what one intends to say when using a keyboard.
Old 01-13-2016, 07:45 PM   #100
Yep! After you reach 70 years old, sometimes what starts out in your head, never reaches your mouth or fingers exactly as it started out.
tire, tires
