Old 03-14-2008, 01:13 PM   #1
Tow Weights
Ok so I am not very smart (get that part out of the way first). I look in my truck manual (2500hd CC SB Duramax Diesel) and I can tow 11000 lbs. I look at lets say a sierra 5th wheel and it says GVWR is 13000+ pounds, but yet I see trucks like mine towing them, are they overweight or are they add on air bags or something or are we back to my first statement??
DW of 12 yrs 6yr old girl, Twin 9yr old girls, 9yr Old boy (10 months between the Three)
2010 Suburban 1500
2006 Sea Ray 185 sport
On the hunt for a new travel trailer
wvsteve is offline   Reply With Quote
Old 03-14-2008, 01:56 PM   #2
the 11,000 lbs is for bumper style towing
for a 5'er you need to look at your trucks GCWR (Gross Combination Weight Rating) I'll bet yours is in the 20,000 lbs + range
that's a valid safety question
aintgotnun is offline   Reply With Quote
Old 03-14-2008, 02:23 PM   #3
There's a few of things going on with that.
1. Some of them are overweight.
2. Some of them have added springs/air bags because they're overweight.
3. Just because the GVWR is 13K doesn't mean it will weigh 13K.
You have to weigh it to know if you're over your TV's rating.
That 13K GVWR 5er might only weigh 10K wet so you could still add another 1000 lbs of gear and still be within your TV's limits.
Another thing to consider is that some makes have separate ratings for tag-alongs and 5er's.
Gotta go campin!
Old 03-14-2008, 09:43 PM   #4
powerboatr's Avatar
hmmm we are rated at 26000 lbs gross combined weight rating
truck is rated at 13k gvwr
our rv routinely goes between 13870 and 15000
we usually bounce out at 24000 + gross
pin is high to, i have had as much as 3500 on the pin
and as low as 2100
even though the book says 1870 for a pin, it aint never happened , even empty.
we weigh if we,
A. have been sitting static for a while, you never know how many old magazines and dead batteries have moved in.
B. are headed out for a long run ( over 500 miles)
C. if i feel froggy and the scales are empty at loves or flying J
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 03-16-2008, 10:44 AM   #5
rexerito's Avatar
Towing Guide
Toyota puts out a pretty good guide on understanding towing.
http://a230.g.akamai.net/7/230/2320/...wing_guide.pdf
Check it out.
Rex
rexerito is offline   Reply With Quote
