Old 08-29-2013, 12:33 PM   #1
Question Towing Issue?
Is this a problem or normal? Towed the camper to the dealer to have the slide adjusted. Only my second time to tow it. I noticed that when I took my foot off the gas the truck seemed to lurch/shudder a bit. Is this normal or does something need to be adjusted?
Also, I have an Equal-i-zer hitch and it makes the most awful noises and there's a thunking feeling under the truck (Nissan Titan)...again, is this normal or is something wrong?
Thanks for helping out a first time owner.
2014 Rockwood 2304S
2011 Nissan Titan
jtintx is offline   Reply With Quote
Old 08-29-2013, 12:48 PM   #2
Not sure about the first question but, if he TV slows faster than the trailer, not using breaks, the trailer will push against the TV which could account for that.
Equal-i-zer hitches tend to be a little noisy. Keep it lubed up and it will be a little quieter. I tend to not notice it as much anymore although you may get looks from those around you but, it does it's job.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is online now   Reply With Quote
Old 08-29-2013, 12:51 PM   #3
acadianbob's Avatar
You might have a sticky driveshaft yoke? Not sure if the Titan has one.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 08-29-2013, 01:13 PM   #4
Badlands's Avatar
The noise you're hearing is normal for this hitch, and as noted, you can lube it. I use a dry lube on the pivot points, as well as on the hitch ball. However . . . according to the manufacturer, lube is not necessary, and not doing so will have no adverse consequences on the hitch. The loud 'pop' or 'thud' can be unsettling when you are new to the set-up, but it's quite normal. Regardless, I love the hitch, and my set-up must be on the money. No sway in the wind (or very little), and no 'sucking' from semi's on freeway situations.
Badlands
Badlands is offline   Reply With Quote
Old 08-29-2013, 01:24 PM   #5
Badlands
X2
2013 Rockwood Mini 2503S
2011 Chevrolet Silverado 1500 5.3L
Bryan2503S is offline   Reply With Quote
Old 08-29-2013, 01:26 PM   #6
jim44646's Avatar
I use a little Vaseline, not really a lube but quiets the hitch down
jim44646 is offline   Reply With Quote
Old 08-29-2013, 01:30 PM   #7
As tempting as it is, I am not going to touch that statement with a 10 foot pole.
Old 08-29-2013, 01:39 PM   #8
jim44646's Avatar
A little slippy slidey never hurt anything
Old 08-29-2013, 01:47 PM   #9
Thanks everyone. I feel more at ease now.
2014 Rockwood 2304S
2011 Nissan Titan
Old 08-29-2013, 02:09 PM   #10
Platokidd's Avatar
I use mower guard graphite on the L brackets and spring bars. It embeds itself into the metal over time and there is no mess! Have to respray from time to time.
Keep the hitch head lube with a good grease or dry graphite.
I like the noise..it scares the woman and i get a kick out of that
MowerGUARD™ - Graphite Undercoating for Mower Decks and Blades
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
towing
