08-29-2013, 12:33 PM
Towing Issue?
Is this a problem or normal? Towed the camper to the dealer to have the slide adjusted. Only my second time to tow it. I noticed that when I took my foot off the gas the truck seemed to lurch/shudder a bit. Is this normal or does something need to be adjusted?
Also, I have an Equal-i-zer hitch and it makes the most awful noises and there's a thunking feeling under the truck (Nissan Titan)...again, is this normal or is something wrong?
Thanks for helping out a first time owner.
2014 Rockwood 2304S
2011 Nissan Titan
08-29-2013, 12:48 PM
Not sure about the first question but, if he TV slows faster than the trailer, not using breaks, the trailer will push against the TV which could account for that.
Equal-i-zer hitches tend to be a little noisy. Keep it lubed up and it will be a little quieter. I tend to not notice it as much anymore although you may get looks from those around you but, it does it's job.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
08-29-2013, 12:51 PM
You might have a sticky driveshaft yoke? Not sure if the Titan has one.
Red Green coffee mugs
08-29-2013, 01:13 PM
The noise you're hearing is normal for this hitch, and as noted, you can lube it. I use a dry lube on the pivot points, as well as on the hitch ball. However . . . according to the manufacturer, lube is not necessary, and not doing so will have no adverse consequences on the hitch. The loud 'pop' or 'thud' can be unsettling when you are new to the set-up, but it's quite normal. Regardless, I love the hitch, and my set-up must be on the money. No sway in the wind (or very little), and no 'sucking' from semi's on freeway situations.
Badlands
08-29-2013, 01:24 PM
Badlands
X2
2013 Rockwood Mini 2503S
2011 Chevrolet Silverado 1500 5.3L
08-29-2013, 01:26 PM
I use a little Vaseline, not really a lube but quiets the hitch down
08-29-2013, 01:30 PM
As tempting as it is, I am not going to touch that statement with a 10 foot pole.
08-29-2013, 01:39 PM
A little slippy slidey never hurt anything
08-29-2013, 01:47 PM
Thanks everyone. I feel more at ease now.
2014 Rockwood 2304S
2011 Nissan Titan
08-29-2013, 02:09 PM
I use mower guard graphite on the L brackets and spring bars. It embeds itself into the metal over time and there is no mess! Have to respray from time to time.
Keep the hitch head lube with a good grease or dry graphite.
I like the noise..it scares the woman and i get a kick out of that
MowerGUARD™ - Graphite Undercoating for Mower Decks and Blades
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
08-29-2013, 05:10 PM
You just get used to how it will act when slowing down.
My 3/4 ton acts totally different when slowing down than the 1/2 ton I had before. But it is "normal".
As for the hitch, I can't really say much.
My hitch has the chains and everyone told me how they will pop and scare you to death.
We have towed ours now just about 800 miles and it popped once. Maybe I am doing something wrong? LOL
Mark B.
2021 GMC 1500
Anderson WDH
