Old 03-04-2016, 09:24 AM   #1
TPMS parameters for tires on minilte 2503S?
The 2016 minilite 2503S I ordered on January 2 should be on its way to my dealer. He gave me the vin# 2 days ago. In anticipation of avoiding tire problems from the Chinese tires I have purchased the TST 507 TPMS(not flow through) system and was wondering what high and low settings you use for the pressure and the high temp parameter when I install them. I know the tires are the 14 inch tires(recommended pressure 50psi).
The dealer is installing the progressive power management system hard wired with remote( EMS-HW-30C). I paid for the part, the installation was free.
I have also ordered the Furion Observation Camera and will install myself. As you can see I want to be safe and avoid most mishaps if possible.
Any tips are greatly appreciated.
campbuzz98 is offline   Reply With Quote
Old 03-04-2016, 12:18 PM   #2
"I know the tires are the 14 inch tires(recommended pressure 50psi)."
If I recall correctly, the instruction manual calls for 10% PSI under and 20% PSI over. So whatever that math works out.
Basically- do what the instructions tell you for 50psi.
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
tire, tires
