Old 10-04-2016, 12:39 AM   #1
TPMS Question
Hello,
I would like to get some input from others who use a TPMS.
I have had my camper for a little over a year now. I finally got a TST TPMS. We had our first trip with it this past weekend. I was looking to get some feedback on the below numbers, PSI and Temp, It all seemed rather good, but I would love to hear from more experienced travelers if these numbers sound or appear to be accurate. Not ever having one of these system, I don't have anything from which to compare.
Not sure if this matter, but the current tires size is ST185/80R13 on a single axle. Cold inflated to 65 psi. On the way home, we had mostly sunny sky's with an ambient temp outside of 79 degrees. So on this 3 hrs drive both wheels basically averaged a PSI of 70-72 degrees with a temp of 88-92 degrees. Most of the drive was on highways with speeds around 60-63 mph.
Thanks in advance,
Mark
2015 FR Classic 625D
2011 Toyota Sienna, AWD
Dodaman is offline   Reply With Quote
Old 10-04-2016, 12:59 AM   #2
raptor's Avatar
In my sprinter cold pressure is 65 psi. My TMPS setting 58 low and 85 high. It was reading 79-80 psi in hot day. As long as it stay in between high and low setting than you are safe. Mine has running this way since August.
raptor
2016 Forester MBS 2401R
America is great
raptor is offline   Reply With Quote
Old 10-04-2016, 01:00 AM   #3
Witch Doctor's Avatar
Originally Posted by Dodaman View Post
Hello,
Thanks in advance,
Mark
Sounds about right to me, My trailer tires are 65PSI also and thats sounds pretty average of what I also see....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 10-04-2016, 07:15 AM   #4
waiter21's Avatar
Your temperatures sound about right. I have a Schrader system I use on my toad dolly, two sensors in the dolly wheels, two sensors in the rear wheels of the car.
These are internal sensors, not the valve stem typs.
On a recent trip in Arizona, coming down a long grade, we had a tire temperature alarm on the dolly, it was approaching 200 deg (115 outside air temp). After stopping, letting stuff cool, I discovered I had a brake caliper that was hanging and dragging on the dolly.
The other tire temps would hang around 20 - 30 degrees above the outside temperature.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2001 Civic
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 10-04-2016, 07:15 AM   #5
I will often see an 8-10 pound rise in psi and temps of 90-95 or even 100 on very hot days. The tires on the sun side are always a couple degrees warmer.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 10-04-2016, 12:14 PM   #6
Sweet. Just wanted to see if what I was seeing was normal. Now I know. I was rolling through that bad rain in Delaware on Thursday and noticed the tire getting hit with the rain was a lot cooler. Pretty cool.. Anyway, now time to get ready to do some cold weather camping. Gotta love it😀
Thx again
Old 10-04-2016, 02:06 PM   #7
So what is the average danger temp on tires????
Davidjeff is offline   Reply With Quote
Old 10-04-2016, 03:24 PM   #8
I can't remember the exact temp. But I recently read a Michelin study that said 180-185 I believe with the max temp when tires fail. I'm sore Tireman can give more details. The TST 507 has preset temp at 158.
Old 10-04-2016, 03:31 PM   #9
Most tires fail at 150 degrees and above, that is why TST presets there temps between 150 and 185 if I remember right, but you can change that if you want but I'll stick with what they suggest....
Old 10-04-2016, 04:27 PM   #10
Iwannacamp's Avatar
Good answers. Set at 140 and keep an eye out after that.
Our new 5er 10-26-16
Days camped 2016 8
Iwannacamp is online now   Reply With Quote
