Old 07-14-2019, 06:49 PM   #1
TPMS temperature readings
Just curious.. How can tire temperatures be accurately measured by a stem-mounted TPMS sensor spinning in free ambient air?
Inquiring minds want to know....Well, mine does anyway..How does it accurately sense temps?
Bunker is offline   Reply With Quote
Old 07-14-2019, 06:56 PM   #2
david_reaves's Avatar
I'm actually wondering that too... I know the TPMS reports a much lower temperature than I get when I check the tire surface and/or hub with an IR remote thermometer.
david_reaves is offline   Reply With Quote
Old 07-14-2019, 06:58 PM   #3
Flybob's Avatar
They can't. The benefit of a temp monitor in the TPMS is the ability to compare tire temps. If 3 of 4 tires are running at 90F and one is 120F you have a potential issue. The temp will vary from one side of the RV to the other if the sun is at a low angle.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-14-2019, 07:04 PM   #4
BandJCarm's Avatar
The sensor is not just on a stick. It's on a hollow tube/stem whose chamber goes into the tire. That's how air gets in when you pump air into a tire. So, the air in the tire as it rolls around is fairly consistent, and some of that same temp air eases up into that hollow tube called a stem. On the end is the sensor.
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 07-15-2019, 03:48 PM   #5
You are basically getting the rim temp, not the air temp. And even then, if it's a rubber valve stem or a metal valve stem that rubber insulated, it will be off a bit. I have not heard yet of a person who has detected a malfunction due to something like a dragging brake but I am sure it might be possible.
Bottom line, look for temps on one sensor that are a lot different than the one that is on the same side of the trailer or all of them if you are traveling at night.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
tpms
