Old 03-27-2015, 06:24 PM   #1
Blog: RVroadtripper.com
hbillsmith's Avatar
TPMS TST-507 to monitor Ride Rite Airbags
Any comments on adding TST TPMS Sensors to the Firestone Airbags fill nozzle?
hbillsmith is offline   Reply With Quote
Old 03-27-2015, 06:28 PM   #2
dannyabear's Avatar
WHY
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 03-27-2015, 06:56 PM   #3
Stormrider151's Avatar
I don't see why it wouldn't work. Probably a good idea especially if your towing a 5er.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 03-27-2015, 07:11 PM   #4
I have a gauge in the panel with the inflate button and deflate button connected to the onboard compressor.
Old 03-27-2015, 09:49 PM   #5
hbillsmith's Avatar
I didn't do the onboard compressor and will just fill em manually. Since I already have a TST set, thought why not just throw one more sensor in the mix.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
Old 03-28-2015, 05:27 AM   #6
fonzie's Avatar
It will work. The one issue that could happen is once you have it set up to (as example) 50 psi truck unloaded and then you hook up trailer, because of the extra load on the air bags, the pressure inside air bags might go up to 65 psi and bring in over pressure reading on your monitor depending on your setting?????? And when driving could be worst as shock load?? Just a thought....worth a try.
Fonzie
airbags
