Old 03-27-2015, 05:56 PM   #1
TPMS - TST TM-507 Factory Reset Question
Does anyone know how to do a "factory reset" to restore the TST TM-507 to the "out of the box" or default condition? I inadvertently programmed one of the sensors to an incorrect position on the screen. I cannot find anything in the manual. There is a note indicating how to set the psi and temperature settings to the default, but, not the sensor positions.
MartyQ is online now   Reply With Quote
Old 03-27-2015, 06:06 PM   #2
mcnabbwr's Avatar
Hold the + button while turning the monitor on.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 03-27-2015, 06:09 PM   #3
mcnabbwr's Avatar
Here's is the insert out of the manual. I believe it will restore all settings so you will need to start over completely.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
Old 03-27-2015, 06:35 PM   #4
fonzie's Avatar
Can you just not reprogrammed the sensor to the correct position and maybe that will erase from wrong position automatically as I think you would not be able to have same code into two different position?
Fonzie
Old 03-27-2015, 07:12 PM   #5
Your suggestion worked. Thanks! The other idea does not work. Turning the monitor on while holding the + button only resets the PSI and TEMP setpoints to their default value.
Old 04-03-2015, 04:27 PM   #6
Received a Reply from TST
TST does care about their customers. Received a phone call today. Another way to re-position a sensor (or remove a sensor shown on the screen) is to toggle to the desired tire and sensor code, and then press SET. The sensor address will go to "ALL - F's", thus erasing the sensor from that position.
factory
