Old 10-21-2015, 01:20 AM   #11
ColoradoRick's Avatar
I'm in Monument and also blow out lines then add -50 Red stuff.
You don't have to blow out the lines but once you do you find that you don't use nearly as much red stuff.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
5-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4
ColoradoRick is offline   Reply With Quote
Old 10-21-2015, 10:53 AM   #12
thx
evergreen1 is offline   Reply With Quote
Old 10-21-2015, 10:54 AM   #13
trailer winterization
thx to you all for your response, much appreciated
Old 10-21-2015, 11:23 AM   #14
ferguson65's Avatar
Originally Posted by KDHfan View Post
I do both as well.
Make sure you winterize the outdoor shower... As well as the city water inlet... And blowout the black tank flush, if equipped.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
This is an interesting point............I winterized mine for the first time last weekend, blew it out with air (from city water inlet) once drained down and WH drained and bypassed. I did the outside shower as well as blew out and pumped antifreeze into the black tank flush. Blew out from the city water connection...................Never thought to add antifreeze in there..................Is that something most of you guys do? I can clean my setup I had for the black tank flush and fill it with antifreeze if needed.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 10-21-2015, 11:29 AM   #15
Georgia Frog Rally 2017
aceinspp's Avatar
Originally Posted by evergreen1 View Post
Do you subscribe to blowing H2O lines out & filling traps, toilet etc with RV antifreeze or pumping RV antifreeze throughout system?
I have a H2O purification system what do you use for bypass line ILO of cannister?
Any hidden areas that need attention that aren't readily recognizable?
thanks all, evergreen 1
I remove the canister and dump the water then reinstall and let the antifreeze fill it and the rest of the system. I also blow the system with air before adding the antifreeze. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 10-21-2015, 11:34 AM   #16
wmtire's Avatar
For the two days a year it get's below freezing here in Louisiana, I usually just blow out the lines.
I have been burned twice in forgetting the outside showerhead, with not disconnecting it, and draining water from the head/line. I've had two crack from the water freezing in them. Just a reminder to not forget that, if you have one.
2011 Flagstaff 831 RLBSS
I've invented a new word. "Plagiarism"
Old 10-21-2015, 11:34 AM   #17
Dave Lyon's Avatar
Originally Posted by CWSWine View Post
X2 - Probably the air would enough but I do both air and pink stuff...
X3....... I set my air pressure at 30 PSI.....and don't forget to open a tap and drain your low water points.
Dave, Southern,ON
2009 GMC K1500 4x4 Crew Cab
2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 10-21-2015, 11:37 AM   #18
aceinspp's Avatar
I did that once never again Later RJD
Old 10-21-2015, 11:39 AM   #19
mark0224's Avatar
X whatever number I am
We reach -50 on occasion over the winter and blowing the lines does good but I don't think the air gets into the pump itself for one and I want it safe. Also there are dips in lines that air does not get out, joints , elbows and other connectors do crack.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-21-2015, 11:46 AM   #20
B and B's Avatar
I do a 100 kph suction drain. We are camping this weekend and I will do a pre winterization drain. I pull the low point drains, open all taps and by time I am home 2 hours later the entire system has no water in it. Then I add antifreeze. I buy this;
RV PLUMBING ANTIFREEZE - ECONOMICAL, 9.46L
The TSC store actually sells this for $8.33 which 2 Canadian gallons
I have never dumped antifreeze and gone out again but maybe this year. We have a large Provincial Park open all winter. Thinking between Christmas and New Years!
I take the water softner into the basement for the winter, just easier.
B and B is online now   Reply With Quote
trailer, winter
