Old 10-20-2015, 01:43 PM   #1
trailer winterization
first travel trailer purchase ever, FLT21FBRS ultralite, & would like some tip or insight to winterize. Live in Colorado mtns @ 8000 ft so fairly cold during winter months. Have been to FR site & reviewed video incredibly helpful.
Do you subscribe to blowing H2O lines out & filling traps, toilet etc with RV antifreeze or pumping RV antifreeze throughout system?
I have a H2O purification system what do you use for bypass line ILO of cannister?
Any hidden areas that need attention that aren't readily recognizable?
thanks all, evergreen 1
evergreen1 is offline   Reply With Quote
Old 10-20-2015, 01:55 PM   #2
TURBS's Avatar
I do both.
Blow out.
Suck antifreeze thruout.
TURBS
2008 duramax
2015 columbus 320RS
2015 camping "31 nights"
Old 10-20-2015, 06:36 PM   #3
KDHfan's Avatar
I do both as well.
Make sure you winterize the outdoor shower... As well as the city water inlet... And blowout the black tank flush, if equipped.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 10-20-2015, 06:44 PM   #4
davel1971's Avatar
first step, drain and by-pass water heater. After blowing out with air, drain the low point drains. Water stays trapped since it has no place to go.
David & Lynn
Old 10-20-2015, 06:50 PM   #5
Ford Idaho's Avatar
Pinked mine last weekend.
No air, I find it redundant.
Old 10-20-2015, 07:02 PM   #6
It's air for me. I don't find it redundant.
Once you blow out the system and start pumping in antifreeze, just as soon as you see pink, it's all good. No chance of it being diluted by what was left in the lines somewhere. Use less antifreeze too.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 10-20-2015, 07:07 PM   #7
Ford Idaho's Avatar
Takes 1 1/2 gallons to do the lines, the last half goes down the traps.
That's less than 8 bucks worth.
Old 10-20-2015, 07:13 PM   #8
davel1971's Avatar
air is free. No sense using antifreeze to push the water out, diluting it at the same time.
David & Lynn
Old 10-20-2015, 07:17 PM   #9
Ford Idaho's Avatar
It is not....
I gotta pay the power bill.....
Besides I doubt it get diluted enough to hurt much.
Old 10-20-2015, 07:37 PM   #10
CWSWine's Avatar
Originally Posted by TURBS View Post
I do both.
Blow out.
TURBS
2008 duramax
2015 columbus 320RS
X2 - Probably the air would enough but I do both air and pink stuff...
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 10-21-2015, 01:20 AM   #11
ColoradoRick's Avatar
I'm in Monument and also blow out lines then add -50 Red stuff.
You don't have to blow out the lines but once you do you find that you don't use nearly as much red stuff.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-21-2015, 10:53 AM   #12
thx
Old 10-21-2015, 10:54 AM   #13
thx to you all for your response, much appreciated
Old 10-21-2015, 11:23 AM   #14
ferguson65's Avatar
Originally Posted by KDHfan View Post
I do both as well.
This is an interesting point............I winterized mine for the first time last weekend, blew it out with air (from city water inlet) once drained down and WH drained and bypassed. I did the outside shower as well as blew out and pumped antifreeze into the black tank flush. Blew out from the city water connection...................Never thought to add antifreeze in there..................Is that something most of you guys do? I can clean my setup I had for the black tank flush and fill it with antifreeze if needed.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 10-21-2015, 11:29 AM   #15
Georgia Rally Coordinator
aceinspp's Avatar
I remove the canister and dump the water then reinstall and let the antifreeze fill it and the rest of the system. I also blow the system with air before adding the antifreeze. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 10-21-2015, 11:34 AM   #16
wmtire's Avatar
For the two days a year it get's below freezing here in Louisiana, I usually just blow out the lines.
I have been burned twice in forgetting the outside showerhead, with not disconnecting it, and draining water from the head/line. I've had two crack from the water freezing in them. Just a reminder to not forget that, if you have one.
2011 Flagstaff 831 RLBSS
Old 10-21-2015, 11:34 AM   #17
Dave Lyon's Avatar
X3....... I set my air pressure at 30 PSI.....and don't forget to open a tap and drain your low water points.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 10-21-2015, 11:37 AM   #18
aceinspp's Avatar
I did that once never again Later RJD
Days camped 2019 62
Old 10-21-2015, 11:39 AM   #19
mark0224's Avatar
X whatever number I am
We reach -50 on occasion over the winter and blowing the lines does good but I don't think the air gets into the pump itself for one and I want it safe. Also there are dips in lines that air does not get out, joints , elbows and other connectors do crack.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-21-2015, 11:46 AM   #20
B and B's Avatar
I do a 100 kph suction drain. We are camping this weekend and I will do a pre winterization drain. I pull the low point drains, open all taps and by time I am home 2 hours later the entire system has no water in it. Then I add antifreeze. I buy this;
RV PLUMBING ANTIFREEZE - ECONOMICAL, 9.46L
The TSC store actually sells this for $8.33 which 2 Canadian gallons
I have never dumped antifreeze and gone out again but maybe this year. We have a large Provincial Park open all winter. Thinking between Christmas and New Years!
I take the water softner into the basement for the winter, just easier.
B and B
trailer, winter
