Old 01-28-2015, 08:22 PM   #1
Transmission Oil
New to RVing...we have a 2010 Sunseeker...looking to change tranny oil....easy on the 450 or is there a place like Jiffy Lube?
stachowski8482 is offline   Reply With Quote
Old 01-28-2015, 08:56 PM   #2
TN_Cruise_Lite's Avatar
Jiffy Lube is fine for oil changes but see dealer for transmission service.
2018 Coleman Light 1805RB
2010 Chevy Silverado 4x4
2013 Salem Cruise Lite 195BH (traded)
TN_Cruise_Lite is offline   Reply With Quote
Old 01-28-2015, 08:57 PM   #3
Crusadernoob's Avatar
My first choice would be to do it my self. I would recommend the chassis dealer, truck shop that is willing to work on it for maintenance if you are not able.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
Crusadernoob is offline   Reply With Quote
Old 01-29-2015, 01:00 AM   #4
1l243's Avatar
I take my truck to a lube change place and the do the transmission. I have had it done a couple of times. The hook up a tank system to the trans lines and let the pump on the trans pull all the new fluid through. It's a complete change not just the torque conveter and pan...I don't mess with the pan and screen at all...
1l243 is offline   Reply With Quote
Old 01-29-2015, 05:48 AM   #5
Do you need to change your transmission fluid, or do you want to do it for comfort?
Depending on your mileage, you may not need to do it yet. Read your Ford Scheduled Maintenance Guide. Our Sunseeker is on a 2010 E-450 chassis. The Service Maintenance Guide says on page 19, for trucks with the TorqShift transmission, to change the fluid and filter at 60,000 miles. It also says on page 47 that if you operate your E-450 at or near Gross Vehicle Weight, which certainly applies to most motorhomes, to change the rear axle fluid at 50,000 miles.
You have to read the Owner's Guide and the Scheduled Maintenance Guide carefully. The Owner's Guide is for all E-series products, and some of the information does not apply to the E-450.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 01-29-2015, 09:10 AM   #6
WestCoastRV'er's Avatar
I've been replacing my front & Rear diffs and transfer case every two years myself and just added the tranny drain/refill (annually) to that schedule. If you are able to do it yourself, its not that much money and can be done a few hours.
Be sure to maintain your tranny normal filter replacement and pan drop schedule. Clean fluids will ensure you get the most out of your vehicle.
Dennis
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 02-06-2015, 11:22 PM   #7
tmhyer's Avatar
I would not use the lube places for tranny service. You don't want that vacuum system used to change your fluid. A simple drain/filter change and refill is all you need.
tmhyer is offline   Reply With Quote
Old 02-06-2015, 11:27 PM   #8
1l243's Avatar
The place I went to does not use a vacuum. The system is tapped into the trucks transmission lines and it uses the normal process of pumping fluid through the transmission. It takes around 15 quarts. A simple drain filter change may get 5 quarts...
