Originally Posted by moondog2000
Good post, I'm learning here. Did not think of adding detergent to the tank but why calgon ? Does it prevent water deposits or does it make the chemicals work better ? Thanks Mike
Thanks Vern;
TO BE CLEAR:
The turboflush should be RUN with an open gate for 15 minutes or so AFTER the dump is complete; THEN and only then; close the gate and let the tank fill for a minute or so and open the gate while the turboflush is still running. This will allow any stuck items to "refloat" and be flushed out.
I do this several times until no TP or "solids" are seen.
The Calgon water softener (NOT salt or conditioner!!!) is added to soften the water and allow the detergent to work well even in hard campground water AND it makes the tank walls slippery so future stuff will be less likely to stick around.
