Old 07-20-2019, 07:19 AM   #1
CentralMePistol's Avatar
Travel with bathroom vent fan on...
I am traveling in the Northeast this weekend... high temps expected.
I always leave the bathroom vent open during travel. With this heat I will also be leaving a small slide window open for air flow. (I donít have a second roof vent. Bathroom vent is at rear)
I was also considering leaving the bathroom vent fan turned on low to help pull the hot air out during travel.
Has anyone done this? Good/Bad/No difference????
2018 Cherokee 274DBH
2012 GMC Sierra 1500
4x4, Crew Cab, 5.3 KDL HD Cooling, 3.42 ratio
Recurve R6 WDH w/Sway Control & SumoSprings
Days Traveled:2019-37 / 2018-30
CentralMePistol is offline   Reply With Quote
Old 07-20-2019, 07:29 AM   #2
Had vents open and windows cracked, but never had a fan running.
TheWolfPaq82 is offline   Reply With Quote
Old 07-20-2019, 07:48 AM   #3
KyDan's Avatar
We've towed with the vents open and closed in hot weather. Didn't really see much difference. If it's hot outside it's gonna be hot inside until you get powered up and the AC cranking.
This photo is when we "landed" in ARK last July after a long day on the road with vents slightly open....
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
KyDan is online now   Reply With Quote
Old 07-20-2019, 10:27 AM   #4
Kasual Kamper
We don't have A/C at home, so what we do during hot days is wait until the outside temperature equals the inside temperature and then close up the house... windows and doors shut, drapes drawn and turn on inside fans to circulate air. When evening comes and the temperature outside drops to equal the inside temperature, we open up all the doors and windows and turn on our whole house attic fan to draw in the cooler air and force the hotter air out of the house.
In your trailer, if you are going to be traveling during the heat of the day, running your fan is only going to be drawing in hot air. In my opinion, you are better off closing up everything tight and then airing out once you reach your destination.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 07-20-2019, 01:07 PM   #5
Old Bleu's Avatar
My concern with towing with a vent open is the lid up and in the wind. Those things seem pretty flimsy to me, and I'd be concerned that it might deform or the lid blow off. Of course, if you have a vent cover over it, like a MaxxAir, I see no problem.
2019 Cedar Creek Silverback 33IK
2016 RAM 2500 Laramie Cummins Turbo Diesel
Old Bleu is offline   Reply With Quote
Old 07-20-2019, 01:28 PM   #6
I found out real quick here in the deep south that during the day, temperatures can reach 100 degrees inside of our trailer while it is being towed with outside temps about the same. Opening a vent even with a fan would do no good. I mounted two Honda 2200 generators on beefed up rear bumper along with auxiliary fuel tank and now run my 15K Air Conditioner while I am towing. I can tow for 8 to 10 hours and burn around 3 gals. of gas between the two generators.
Walholler is offline   Reply With Quote
Old 07-20-2019, 02:14 PM   #7
stormer's Avatar
or simply tow up north where it's not so hot.
(currently in Rapid City, SD)
Last time we had vents open, going through construction areas we sucked a bunch of dirt and dust into our RV. That won't ever happen again. We keep everything shut and deal with the heat once we get to the destination. It don't take long to air out the trailer and such once we are setup on AC.
James & Aimee
2018 Rockwood 2906WS
2012 Ram 2500HD 6.7L Cummins
Equal-i-zer 4 Point Hitch
stormer is offline   Reply With Quote
Old 07-20-2019, 02:35 PM   #8
Get a vent cover like a MaxAir to protect the vent cover and leave the vent open. It will develop it's own suction to pull air through the TT.
2011 Traverse LT, 3.6L, FWD
Old 07-20-2019, 03:11 PM   #9
AKA: 'tiredTeacher
awellis3's Avatar
And that air will include dust, carbon monoxide and vehicle exhaust particulates.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 07-20-2019, 06:03 PM   #10
He may get this if he runs his fan or not. He wants ventilation; I'm just telling him he doesn't need to run the fan to get it.
If you want to tell him to bottle up his TT on the road, feel free. You don't need to rain on my parade to do that.
Old 07-20-2019, 08:04 PM   #11
NXR
NXR's Avatar
That's only three degrees of latitude north of us in NE Ohio and it got to 97 today. The motorhome is parked in the driveway and it eventually got there as well in the late afternoon. We just keep it closed up and all blinds drawn.
Ray
NXR is offline   Reply With Quote
Old 07-20-2019, 08:21 PM   #12
PPST Wannabe
kenandterry's Avatar
Forget the fan, and only leave the vent open if you have vent covers like Maxxair.
The lids alone are pretty flimsy in the constant wind going down the road.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 07-21-2019, 06:57 AM   #13
KyDan's Avatar
We do have vent covers.
I would never tow with a vent open without a cover as mentioned the lid is pretty flimsy on its own.
We used to tow with a vent open but wife decided it caused more road dust to filter inside than when it's closed so we now tow with the vents closed.
As I said earlier I didn't see much temp difference either way.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 07-21-2019, 07:05 AM   #14
jeff64's Avatar
X 3 on just open covered vents. My vents are only closed with ac on
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 07-21-2019, 09:31 AM   #15
Wolverine 1945's Avatar
Not sure we could tow that far North ???
Wolverine 1945 is offline   Reply With Quote
Old 07-21-2019, 10:25 AM   #16
Basically the air we breath everyday. But toss in...Pollen, mold, spores, bacteria...and a couple hundred other things. I get what you're saying.
Old 07-21-2019, 06:12 PM   #17
rollscanardly's Avatar
I believe that a closed up thing...(RV, home garage, etc.) stays a little cooler on a hot day, by not letting hot air get into it in the first place.
It's 100 degrees here this weekend, in New England. My garage (30' x 30') and back shed (24' x 34') are sealed up pretty good..no open doors or windows.
It's quite a bit cooler in these buildings than the outdoor temp. Very bearable.
Rich
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2004 Dodge Ram 2500 Quad cab, 5.7L Hemi, 4.10 gears.
rollscanardly is offline   Reply With Quote
Old 07-21-2019, 08:43 PM   #18
Lets go camping!
str8t six's Avatar
both our vents are open 24/7 unless we have the AC going.
2014 Rockwood Mini Lite 2504s
2016 Ram 3500
str8t six is offline   Reply With Quote
Old 07-21-2019, 08:59 PM   #19
SilhouettePenny's Avatar
I concur with this scenario, road dust and engine exhaust will find their way into the camper if a window is open, especially on the exhaust side of the vehicle. Close it up, travel then walk the dog while the unit is cooling off after arrival.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 07-21-2019, 09:46 PM   #20
We had the same experience driving on a bunch of gravel roads in Iowa. Everything in the trailer was coated with dust.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
bathroom, fan, roo, travel, vent
