Old 03-20-2015, 12:45 PM   #11
My spare 20# is carried in the basement surrounded by other things. No room for it to tip over.
Old 03-20-2015, 12:51 PM   #12
B and B's Avatar
Originally Posted by OldCoot View Post
Are you forgetting the twin 30# cylinders and 8' of rubber hose right under the bedroom?
I know and but they are in a non combustable? lined cabinet with no floor to allow propane to fall out from should a leak occur... that is what i have been told
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 03-20-2015, 12:57 PM   #13
geotex1's Avatar
Originally Posted by S1LV3R4D0 View Post
Old milk crate here too. Which got me thinking about how much explosive things i haul around when camping. Between the fuel cans, the extra propane and the ammo, i should have a freakin hazmat sign on the bed of my truck, lolol.
Just get you 40-hour OSHA HAZWOPER with 8-hour annual refreshers, your DOT HMR awareness, and first aid/CPR and you're set!
geotex1 is offline   Reply With Quote
Old 03-20-2015, 01:01 PM   #14
Have a good look, the floor is metal, but it is open to the belly which will leak gas into the entire belly plus the 8' of rubber hose that runs across the front, etc. Just don't think it would be any more dangerous than carrying the propane cylinders for lantern, grills, etc. If one of those leak, there will be a major problem anyway if somehow they were ignited.
Old 03-20-2015, 01:09 PM   #15
I haul a 20lb'er in my truck bed all the time in a plastic milk crate. soft tonneau cover, never had any issue. last year for deer camp since we were dry camping I put a 40lb'er in my big cooler in the bed of my truck and hauled it that way, no issues either
steveh326 is offline   Reply With Quote
Old 03-20-2015, 01:10 PM   #16
CSMRetired's Avatar
Milk crate in the basement.
My understanding is propane will 'pocket' and not necessarily dissipate. Even with an open compartment in your coach, TT, 5th wheel, pop up and so on if you have an ignition of some sort......you 'will' have a major major problem most likely too soon to worry about.
'Pa Pa's Palace'
2014 Sportscoach Crosscountry 405FK
2015 Jeep Grand Cherokee Overland
CSMRetired is offline   Reply With Quote
Old 03-20-2015, 01:14 PM   #17
Agree with CSCRetired 100%.
BTW, never heard of propane pocketing, anytime I smelled a leak, it went everywhere, but I suppose it could pocket.
Old 03-20-2015, 01:15 PM   #18
S1LV3R4D0's Avatar
LMAO ill just wing it
Doug and Toni & Penny
2014 Wildcat Maxx T28RLS TT
2013 Silverado Z71 5.3L 3.42gears
Nites Camped 2015: 21
S1LV3R4D0 is offline   Reply With Quote
Old 03-20-2015, 01:24 PM   #19
B47
It would appear from reading here that a lot of dairies are missing their plastic milk crates.
B47 is online now   Reply With Quote
Old 03-20-2015, 01:25 PM   #20
CSMRetired's Avatar
[QUOTE=OldCoot;811614]Agree with CSCRetired 100%.
BTW, never heard of propane pocketing, anytime I smelled a leak, it went everywhere, but I suppose it could pocket.[/QUOTE
so if you do have an open bottom, it will dissipate
I did fail to say that when we arrive at a CG, the first thing I do is take the propane bottle out of the basement and leave the door open while I am setting up......just in case
Propane Vapor
Propane becomes a vapor at temperatures above -44F. Similar to water when it boils and gives off steam, propane gives off vapor when it boils. One may refer to propane vapor as "flammable steam" for simplicity. However, for the propane vapor to be ignited, there must be the right mix of air and vapor. Propane vapor is heavier than air and will sink to and collect in the lowest point it can find. If propane is vented to the outside air, it will quickly dissipate with the slightest movement of air. Conversely, if propane is vented into an air tight structure with no air movement, the propane vapor will collect on the floor and rise vertically if more propane is vented into the structure.
This is extremely important to know because if there is a propane leak in a house or building, the propane vapor will seek the lowest possible point where it will collect. Keep in mind that one gallon of propane will produce over 36 cubic feet of vapor and this vapor will settle in the lowest possible place. If the propane vapor level continues to rise, it may ignite if finds a source of ignition. The weight of propane vapor being heavier than that of air is a characteristic of propane gas that needs to be understood by all LP Gas users, not just propane companies and their employees.
'Pa Pa's Palace'
propane, tank, travel
