Old 03-22-2015, 01:01 PM   #41
vinmaker's Avatar
I think most people equally carry them in the bed of a pick up truck or in the actual RV. I have not heard of any problems or disasters in the news. I do not think it is a big problem. Just make sure the values are closed up tight.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 03-22-2015, 01:24 PM   #42
CSMRetired's Avatar
Originally Posted by RubyDually View Post
I believe somewhere it's written that you cannot transport propane cylinders or gas jugs on the back of your camper in case you're rear ended.
I do know someone who was pulled over because he had a propane tank mounted on the back of his truck camper. Wasn't fined or anything... Just educated he had to move it.
Maybe in Canada, but as I said before. ...after extensive search, I have not nor can not find any laws governing transportation of personal use propane bottles.
Common sense however, should prevail.
I carry one in the basement of my motorhome sitting inside a milk crate so it won't topple over.....I did the previous research in order to make sure it wasn't illegal anywhere. .....it is not as far as I can tell, illegal in the US or I would not do it.
'Pa Pa's Palace'
2014 Sportscoach Crosscountry 405FK
2015 Jeep Grand Cherokee Overland
CSMRetired is offline   Reply With Quote
Old 03-22-2015, 01:32 PM   #43
fonzie's Avatar
Some info for Canada......
http://www.mutualpropane.ab.ca/Porta...eCylinders.pdf
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 03-22-2015, 01:35 PM   #44
CSMRetired's Avatar
Originally Posted by fonzie View Post
Well, there ya go.
'Pa Pa's Palace'
Old 03-23-2015, 10:36 AM   #45
2007 WildCat 32QBBS
05CrewDually's Avatar
Originally Posted by CSMRetired View Post
Well, there ya go.
So if you follow the recommendations, folks transporting tanks in the basement of the 5er need to have the door open slightly for ventilation.
05CrewDually is offline   Reply With Quote
Old 03-23-2015, 11:11 AM   #46
Assistant TP Supervisor
B and B's Avatar
If I transport my 100 lb cylinder to Costco I have to tie up vertically in my utility trailer along with several 20 lbs in milk crates. According to the rules I am over the maximum but they are certainly open air. I see a lot of roofers with 100 lb cylinders lying down like torpedo's in the back of the pickups.
Old 03-24-2015, 10:48 AM   #47
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by mjones12 View Post
My pickup has a soft tonneau cover. Would that make it too hot to safely carry a full tank back there in summer?
Did it for 3 years - no problem.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 03-26-2015, 09:31 AM   #48
Smile
CSM - very good teaching lesson. Hope all travelers understand.
utahlucky is offline   Reply With Quote
Old 03-26-2015, 09:43 AM   #49
CSMRetired's Avatar
Thanks, just putting up what I found and do. Folks are going to make their own decisions based on personal preference and what they feel is safe or accurate.
'Pa Pa's Palace'
propane, tank, travel
