10-23-2018, 07:35 PM
Trouble with LED lights and tank level sensors
Does anyone know how to remove the cover off these lights. I am having trouble with one and dont want to break the cover removing it. Also, after I empty my gray tank, it still has two lights lit. Is there any way to check the sensors?
10-24-2018, 11:38 AM
It looks like mine so assuming it is.....
To open grab the cover and turn counter clockwise. It is not a screw on cover, it only turns a 1/4 inch or so. Hope this helps.
10-24-2018, 11:41 AM
Yep, turn counterclockwise. Tank lights are notoriously not accurate.
10-24-2018, 12:31 PM
The sensor has some crud stuck to it. The next time you dump the tank it may come off the sensor or may not.
Sometimes my sensors register properly and other times way off the mark.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
10-24-2018, 01:43 PM
code.org
GEO Method
Try the GEO method on your tanks. Every time I move the trailer I use it on both tanks. Original sensors still reading correctly.
https://sites.google.com/site/cbruni/
Randy, Mary, and Mojo
Rockwood Signature UltraLite 8329SS
2001 Dodge Ram 2500 Cummins Diesel / Allison Trans
2015-14 Nights, '16-90 Nights, '17-101 Nights, '18-146 Nights, '19-76 Nights '20-56 Nights '21-42 Nights '22-86 Nights '23-65 Nights
10-24-2018, 02:41 PM
And they are a bear to turn. My arthritic hands can barely turn them.
10-24-2018, 04:09 PM
Originally Posted by moff34
Thanks for sharing this!
2019 FR Cherokee Wolf Pack 24pack14+
2019 Ford F250SD 4 x 4, 6.2L
2015 DL1000A ADV
2017 DR-Z400 SM
10-24-2018, 04:42 PM
Tank sensors
Tank sensors are the most useless items on. an rv.....there are sensors that work but not the ones that come on RV's from the factory. The factory's will not spend the extra money to deliver a quality product....just cheap cheap junk
10-24-2018, 08:13 PM
My Sensors work just fine. I think that sometimes sensors may not work well because of user error
Central Florida
2017 Nissan Pathfinder SL
2019 Shamrock 19
10-24-2018, 09:21 PM
Just as confused as you
Not much room for user error when the sensors installed by the factory is nothing more than bolts stuck through the tank wall. Horst Miracle Probes are a wire type probe with a shield that prevents tp and solids from making contact. SeeLeveL II RV Tank Monitor are non-immersive sensors that attach to the outside of the tank and are said to be very reliable.
Richard & Jill
10-24-2018, 10:56 PM
I'm Lost
Decon Blue and Ilgander,
How do teens and 20 somethings know what clockwise and God forbid counterclockwise means?
With all the digital clocks around, then in the UK the colleges are removing all analogue clocks in exam rooms as the students are stressing on timed tests as they cannot figure time remaining?
Sorry just an observation.
Geoff
Geoff, Francesca and Lucy the Golden holy terror (I mean retriever, BD Nov. 2018)
2023 F150 Screw, 3.5L, HDPP, LT tyres.
2013 Rockwood Signature 8310SS
2023 F150 Lariat 502A (After all rebates, price protection and dealer discounts, I saved $12,600Cdn. (Cavalcade Ford). If pays to shop dealers! (April 2023)
