Old 09-07-2011, 10:40 PM   #31
Brigitte
boubou's Avatar
Talking
Originally Posted by sherdep View Post
I know your truck is rated for more horsepower then mine is (Mine is rated at 345hp) so that may be the diffrence of why you have the 3.55 with the 20's - for better fuel economy at highway speeds plus you have MDS which cuts off 4 cylinders or two banks if I remember correctly.
I say drive it with 20's and see how it performs - I know Labzy is running the same setup as you are except she has a Mini Lite 2306 - you might be able to get some info from her on driveability issues if she has any - she does her homework so she will tell what she has dealt with.
We did the same as a lot of people, didn't look around that much. Really liked the Shasta revere and wanted the slide. Ended up with a heavier tt thay I wanted to pull. It will be ok, within my truck's limits but lighter would have made me feel more at ease. I did not realize the tongue weight was so high 750 dry) so a bit challenging with wd but that's a different thread.
Thank ya all friends, bed time for me. I'm sure I'll be counting trailers to fall asleep
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 09-07-2011, 10:43 PM   #32
Brigitte
boubou's Avatar
Oh and reason i got a non lite tt is my brother in law sold tt for a few years with his familly business and suggested I stayed with conventional tt stick and tin
Superglide 2700
Timbrens
Old 09-07-2011, 10:47 PM   #33
sherdep's Avatar
no need to explain - it is all good
I doubt its really gonna make that much of a diffrence since it is a 21 footer - if it was a 25 to 30 footer it would
your trailer weighs 7,500 pounds - tongue weight is usually 10% since you said 750lbs
oh and good night
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 09-08-2011, 05:57 AM   #34
Wanna Be Camper
SaskCampers's Avatar
Still have the same poorly geared tranny though and with 3:73's and the 32 inch factory size tires is not ideal so I cannot imagine having 33's with 3:55's being a great combo. Seems like it could be a recipe for tranny overheating down the road with a heavy load.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 09-08-2011, 07:51 AM   #35
Malco's Avatar
If you stay off gravel roads while towing your trailer your wranglers should be alright,we have the same tires and have had no issues but a friend drove a stone through one of his while towing on a gravel road because of the extra weight on quite a soft tire.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 09-08-2011, 06:44 PM   #36
chadster1's Avatar
I have a 2010 Dodge Ram 1500 QC with 3.93 gears. I upgraded my tires to the Goodyear Wrangler DuraTrac LT 275/65 r 20. They fit......barely in the wheel well. As someone else has mentioned, you are limited in LT tire selection in 20". I used my Superchips Flashpaq to reprogram the computer since these tires are taller than the stock size.
2011 Cherokee Wolf Pack 27WP
2008 Dodge Ram 1500 Laramie. 5.7 Hemi, Helwig 2500lb springs, Bilstein shocks, Superchips Flashpaq.
chadster1 is offline   Reply With Quote
Old 09-09-2011, 10:50 AM   #37
(Kim)
Labzy's Avatar
I have a question that relates here.
My Ram tires are the same as boubou's, rated 114, (2600lbs per tire at max pressure of 44psi).
Inside the door is the recommended psi for the tires which is 35psi.
I know you are supposed to add a bit for towing, so I was wondering how much extra psi do you guys/gals put in?
Also, how much does this effect the load rating (lbs per tire)?
Thanks in advance for your help
Kim
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 09-09-2011, 11:07 AM   #38
Triguy's Avatar
Kim
35psi is the cold max so its advised that you inflate to 35psi; but no more. The tire is built to go beyond that as its heats up so you don't need to inflate more than it's max.
Also, that's the door sticker, which is the correct PSI assuming those tires are OEM. Follow the max psi on the tire when and if you change from the OEM tire.
Kim
The load rating is based on your max psi. You cannot increase the load rating by inflating beyond this max. However, you can decrease the load rating if you underinflate.
Replacing your tires is the only way to change the load rating.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-09-2011, 11:20 AM   #39
(Kim)
Labzy's Avatar
Thanks Scott
But I have yet another question now.......
How much do I lose from the load rating at 35psi?
Do you guys not add a few more pounds when you tow? (like up to 38psi?)
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 09-09-2011, 11:48 AM   #40
chadster1's Avatar
Thanks Scott
You do not want to inflate over the max psi stated on the tire or you will get premature wear down the center of the tread pattern. I found this out the hard way on my tires before I upgraded to LT tires. I killed a set of BFG 275/60/R20 in 20k miles by running 40psi when towing.
tires
