Old 09-09-2011, 11:53 AM   #41
Malco's Avatar
Originally Posted by Labzy View Post
Thanks Scott
But I have yet another question now.......
How much do I lose from the load rating at 35psi?
Do you guys not add a few more pounds when you tow? (like up to 38psi?)
I have the same tires and I have been running 37 lbs in them all the time.It seems to take the sloshyness out of them.Any more and the bumps are very noticeable.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 09-09-2011, 12:48 PM   #42
Herk7769's Avatar
Originally Posted by boubou View Post
Goodyear p275/60/R20
Max weight 2601 lbs
Max Weight of 2601 is a Load Range 114 tire.
In fact it is a 114S from the Goodyear web site.
Speed Range S equals 112 MPH.
With that basic information we are NOT done.
It must be inflated to its maximum inflation pressure cold of 44 PSI to carry that load. HOWEVER, when Passenger car tires are used on trucks and SUVs they REDUCE the maximum allowable load on the tire by a factor of 1.1; thus the maximum allowable inflation pressure is 35 PSI which equates to a maximum load of 2365 pounds not 2601. (see page L-10 of the Goodyear load and inflation pressure manual.)
The Door post is a manufacturers recommendation for inflation that takes into consideration several factors in addition to maximum load. While the door post PSI will NEVER be higher than the maximum load bearing pressure; is almost always less. Sometimes a LOT less. That pressure is based primarily on RIDE factors (braking, cornering, and vehicle roll) at the curb weight of the vehicle and the OEM tires.
http://hmcclub.homestead.com/Goodyea...oad_Charts.pdf
The single exception to the above has to do with P tires that are branded XL. In this case the following "note" applies (taken from the Tire Specification" document below).
The load-carrying capacity of P-Metric tires is rated either Standard Load or Extra Load. The load that can be carried with a maximum inflation pressure of 35psi limits standard Load tires. The load that can be carried with a maximum inflation pressure of 41 psi limits extra Load tires. An Extra Load tire (for example P235/75R15XL) will be branded with “Extra Load” as shown in the photo on this page. A Standard Load tire does not bear any special designations.
References:
http://www.cjtire.com/pdf/Tire%20Identification.pdf
Wrangler SR-A
HAM CALLSIGN - KC3FFW
Old 09-09-2011, 02:20 PM   #43
Brigitte
boubou's Avatar
Lou, I am not asking Google anymore, you get to the point a lot quicker! Thanks for the info, it will come in handy.
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 09-09-2011, 07:56 PM   #44
(Kim)
Labzy's Avatar
Now that's what I'm talking about!!!!
~Thanks Lou
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 09-11-2011, 05:44 PM   #45
Malco's Avatar
References:
Wrangler SR-A
Herk Why is the maximum load of a passenger tire reduced when used on a truck.If it is rated to carry a certain amount of weight,wouldn't it carry the same amount no matter what it was on?
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
Old 09-11-2011, 05:52 PM   #46
Rugged Brown's Avatar
I know what you're saying. If I need to find anything out I just "Lou it" now rather than Google it.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 09-11-2011, 07:29 PM   #47
Herk7769's Avatar
http://www.cjtire.com/pdf/Replacement%20Tires.pdf
I yield to the Goodyear engineers here.
This document seems to sum up the logic though.
Old 09-11-2011, 07:51 PM   #48
Malco's Avatar
Interesting,Thanks for the info.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
Old 09-11-2011, 08:42 PM   #49
Herk7769's Avatar
A trip to the tire store in your future?
Old 09-12-2011, 03:15 AM   #50
Malco's Avatar
Tires have 47000 kms on them so they have to soon be replaced anyway,already had plans to get a Michelin LT tire to replace them.I had them on my other truck and got 90000 kms out of them.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
tires
