Old 03-30-2010, 01:34 AM   #11
I have the same problem
Rick I have the same problem, the tires rub on the slide side of my 2010 salem 26TBUD. Keep me posted on what you find out?
Cheers Wade
Canadian True North is offline   Reply With Quote
Old 03-30-2010, 02:37 AM   #12
I would go back to the factory service people with this problem.
The factory probably installed the wrong springs or something of that nature.
My Forest River Rockwood came with 3 rims that matched the VIN tag and 1 that didn't, so they do make mistakes at the factory.
John U
2007 Rockwood 8315SS
2014 Silverado 2500HD 6.0L
midnightpumpkin is offline   Reply With Quote
Old 04-12-2010, 07:02 PM   #13
Big Show's Avatar
**update**
Hello All..
Thanks for all the replys.... Well I haven't had the chance to go to the dealer yet....But I was able to move the camper out and go under to check things out. The tags on the axles seem to match what the sticker shows for axles. So I am not sure whats wrong.... It has the right size tires... and we don't carry much stuff, so I know we are not over loading it....
I took a few pic's if anyone wants to see....
http://s856.photobucket.com/albums/a.../2007%20Salem/
Rick.................Warwick, RI
2007 Salem LA 272BHSS
2006 Silverado LT2 1500 Crew Cab 2WD 5.3L/3.23
2003 Yukon XL SLT AWD 5.3L/3.73
Reese Dual Cam WD Hitch
Big Show is offline   Reply With Quote
Old 04-13-2010, 11:30 AM   #14
milzat's Avatar
From looking at your photo, the spring packs may be too light for your trailer weight. The spring pack should have more of an arch.
milzat is offline   Reply With Quote
Old 04-14-2010, 07:07 PM   #15
Big Show's Avatar
Thanks Mike.....how would I find out what I should need?
Old 04-14-2010, 08:10 PM   #16
milzat's Avatar
Rick,
Check with Palmer Spring Co‎. in Providence or Arcand Spring Co Inc‎ in Cranston. Both service RVs and should be able to let you know if the spring pack on your trailer is too light.
Old 04-16-2010, 07:42 PM   #17
Big Show's Avatar
Rick,
Thanks Again Mike......I will check them out..
Old 04-17-2010, 08:50 AM   #18
AKA KE2DX
Don and Elaine's Avatar
I had a similar problem with my Cherokee TT. Turns out the springs were not strong enough for the weight rating of the trailer. I had new springs installed with a higher weight rating and it solved the problem. Check your tires for wear and replace if there is any non road wear.
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 50 days in 2015, 74 days in 2016, 92 days in 2017.
Don and Elaine is offline   Reply With Quote
