Old 04-10-2012, 01:43 PM   #1
Turning radius, fifth vs TT
It seems like I have to swing wider with my new 21rr than I used to with my 30' fifth wheel. Can this be? It's been a few years since I had the fifth wheel so maybe it's just a memory thing. Curious in Kansas.
comfun1 is offline   Reply With Quote
Old 04-10-2012, 02:34 PM   #2
TURBS's Avatar
You can turn way shorter with a 5er .
So much so that its not even close.
Old 04-10-2012, 02:46 PM   #3
DAISY BOYKIN's Avatar
You are right!
It takes less turning radius for a fifth wheel than a TT. This was one of the first things I noticed when I went from a 26" TT to a 31" fifth wheel.
About half the distance.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 04-10-2012, 03:13 PM   #4
Herk7769's Avatar
The TT "should" track the same ground path that the truck's wheels trace in a gradual turn. "If the truck made it; the camper will, too."
The 5th wheel will always track to the inside of the turn.
My "curb strike" occurred when I was pulling onto the highway. I did nothing different than when I pulled out with the rental TT and wham; hit the curb. Now I know to watch out for the camper turning tighter than the truck.
HAM CALLSIGN - KC3FFW
Old 04-10-2012, 06:05 PM   #5
I went to a large parking lot and made a sharp turn like you would find in a residential neighborhood. I turned sharp as opposed to swinging wide and marked the tire tracks with chalk. There was 9' of difference! The wider the turn the smaller the difference becomes. I don't think it was quite as much with my fifth wheel. Also I'm wondering if the axles may be set a little further back on a toyhauler to help with the load in the garage.
Old 04-10-2012, 06:17 PM   #6
TURBS's Avatar
ideally you could put the 5er in a zero degree spin. It would spin around on its tire but not move .
Old 04-10-2012, 06:18 PM   #7
Well, not having a 5er but just from an engineering perspective, one would expect the 5er to have a smaller turning radius when you look at where the pivot points are in relation to the TV axles.
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 04-10-2012, 06:21 PM   #8
TURBS's Avatar
Correct !
you could spin a 5er 90 degrees of tv if not a little more . Thats impossible with a tt.
Old 04-10-2012, 06:57 PM   #9
Steve Jackson
sideout1961's Avatar
How sharp can you turn a tt with a wdh attached? Can the TV go 90 degrees to the trailer or is this impossible?
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 04-10-2012, 07:09 PM   #10
turbo, you're not paying attention to comfun's original post, he said he has to "swing wider" in a turn with his shorter TT than with his old fifth, so he doesn't hit something, and you are talking about something completed unrelated.
comfun, that is odd, no doubt. Even if the axles on the toyhauler are set back farther, one wouldn't expect them to be farther back than on a much longer fifth. And as the rear bumper of the TV swings out in a turn, that also helps the TT follow. The hitch point on a fifth is well inside of that curve.
Strange indeed.
