Old 09-11-2011, 08:51 PM   #1
TV cable
I took out my new FR Flagstaff 5th wheel this weekend for a shake down. The only problem I had was the TV cable if i pluged it into the trailer box on the outside I could not get a picture. If i pluged it directly to the tv it was fine. I tried every combo on the control box with the radio, DVD, stuff and all that couldnt get a picture. Does anyone have any suggestions? Help
Rabidd is offline   Reply With Quote
Old 09-11-2011, 09:04 PM   #2
Redheaded blue tick's Avatar
turn off the 12volt amplifier for your roof mount antenna
Pat and Angela Malerk
2017 Dodge 3500 Diesel Dually 4x4 towing
2011 Rockwood Windjammer 3008W
Hitch: 1200 Equalizer
Redheaded blue tick is offline   Reply With Quote
Old 09-11-2011, 09:07 PM   #3
Herk7769's Avatar
Turn off the AMP while using cable and turn it on to switch from cable to roof antenna.
The switch is that tiny black button with the green LED in the plate.
Always turn the switch off (light out) because it is a parasite drain on your battery when not on shore power.
Always do a channel search after switching from roof to cable and vice versa. Remember to select cable or AIR when you do the channel search to tell the TV what tuner to use.
Name:	Sandpiper Cable connections Bedroom.jpg
HAM CALLSIGN - KC3FFW
Old 09-12-2011, 07:01 AM   #4
Lottery Non-Winner
Ovair's Avatar
And make sure you ran the cable to the right connection on the outside. Generally a connection on the passenger's side of the rig is where you would connect an outside TV for viewing, and a connection on the driver's side of the rig is where the source cable brings the signal into the rig.
Not trying to be insulting, but it seems a lot of people miss that.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 09-13-2011, 09:01 PM   #5
TV Cble
Thanks for all the info I tried all that, but no joy. I guess I must take it in but will try one more time. Thanks
