Old 07-28-2008, 09:18 PM   #11
wildwood's Avatar
i use the screw tire stops and have the four corner stabilizers and still have the bounce in the tt, it is 34 ft long. I also use multiple wooden blocks under each corner stabilizer.
i plan to buy a pair of stabilizers like i have on my corners from camping world, est cost 80.00 and install near the middle of my trailer on the I beam, in front of wheels. I talked with another trailer owner that had recently tried this with good success.
the best is the cross braced system, a bit pricey for the installed system from some of the ones i have seen, but depending on the number of times you go camping and the number of people in camper, may be worth it.
2008 Wildwood LE 29BHBS
wildwood is offline   Reply With Quote
Old 07-29-2008, 07:59 AM   #12
BAL also makes some add on bars that attach to your frame with drilling and screws, and the other end to the bottom of your existing un-stabilizers. They cost 50 bucks a set, and you'll need 2 sets, but they work. I tried the wheel things that go between and jack outward to lock the wheels, but they wouldn't fit mine! Too close together! I will try to find more later, but for now, I'm getting the stabilizer bars. Randy
Old 07-29-2008, 01:09 PM   #13
hunt4240dw's Avatar
Send a message via MSN to hunt4240dw
The Ultra Deluxe Chock and Lock RV Stabilizer will work on the Vlite because the closed distance is 1 and 1/2 ins. I use them on both sides to stop the front to back. I have bought and going to try this weekend stabilizers for the slide out rails to stop the side to side when some moves on the slide outs.
The Hunts
2012 F150 Ecoboost, 3.55, tow package
Equal-i-zer Hitch
2009 Flagstaff V-Lite 30WRLS
1982 16' Glastron Ski boat
hunt4240dw is offline   Reply With Quote
