Old 05-16-2013, 07:09 AM   #1
mjones12's Avatar
Unbolted battery
I noticed that the battery box in my new camper had a small amount of water in the bottom, so I pulled up the battery and was surprised to find that the box was not bolted to the frame. There is a one-inch strap that goes under the frame and snaps together at the top. I thought it was just to keep the cover from blowing off, but apparently that is all that keeps the battery box from moving.
Is that sufficient, or did the dealer forget to bolt it down? At the very least, I'm going to drill a couple of holes in the bottom of the box to let any water drain out.
I just had the camper on a mountainous trip with steep, curvy and bouncy roads, and the battery doesn't seem to have moved at all. Should the box be bolted down or is the strap sufficient? Thanks.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 05-16-2013, 07:12 AM   #2
TURBS's Avatar
Should be bolted down.
I also drilled drain holes.
Turbs
Old 05-16-2013, 07:19 AM   #3
Since we store ours in a storage lot, I just use one of these, seems to keep things in place just fine.
B & D RV Battery Lock For RV travel trailers and popup campers.
lundah is offline   Reply With Quote
Old 05-16-2013, 07:24 AM   #4
Suggest stainless steel carriage bolts in the corners.
Old 05-16-2013, 10:12 AM   #5
One more thing to check. Thanks!
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
Doering is offline   Reply With Quote
Old 05-16-2013, 11:24 AM   #6
tanddc's Avatar
I supplied my own battery box and just use a bugee strap to hold it down. I have mine in public storage so the strap makes it easy to remove. I had the same set up on the pop-up. Never had any problem with it moving.
tanddc is offline   Reply With Quote
Old 05-16-2013, 11:33 AM   #7
w4drr's Avatar
Ours just came with the standard-issue nylon strap holding it down, and never had any problems with the battery moving. I did have to drill some drain holes in the bottom of the box, though.
Bob
Bob & Doris
Roanoke, VA
2009 Toyota Tundra CrewMax 4x4 - 5.7L - 6 Speed Auto - 4.30:1
2013 Rockwood HW296
w4drr is offline   Reply With Quote
Old 05-16-2013, 12:18 PM   #8
bikendan's Avatar
the nylon strap is pretty standard on travel trailers. i also bolted both of mine down when i went to a two battery setup for dry camping and boondocking.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-16-2013, 12:39 PM   #9
NYDP77's Avatar
Turbs
X2
DP
2013 Tracer 240 AIR
2014 Silverado 1500
NYDP77 is offline   Reply With Quote
Old 05-16-2013, 01:17 PM   #10
I bolted down the battery on my pop-up, but on my TT I added a 2nd Battery and secured it the same way next to the original - with a strap.
The downside of bolting it down is that any acid that makes its way out of the battery will corrode the bolts. If you do decide to bolt it down, you should drill drain holes, but beware, any acid leaking will attack nearby metal frame parts.
Personally, I prefer the simple strap method. There is no metal to corrode and it contains any leakage in the battery box. You should check the box after rain or washing as water will enter through the vent holes in the top of the battery box and pool up in the bottom. It's a good idea to do your battery maintenance then.
Tim295 is offline   Reply With Quote
