Old 09-14-2016, 05:13 PM   #1
Underbelly
The "sealed" underbelly of my 2015 Flagstaff is really unacceptable. Sagging, barely anchored. I'm sure rodents will love it in there. Anyone got any creative ways to improve the situation?
larrybessette is offline   Reply With Quote
Old 09-14-2016, 07:04 PM   #2
northstar1960's Avatar
Take it down . add extra insulation [2"] foam board . tighten all fittings, cover tanks , wrap pipes in insulation [pipe wrap] re install using more fasteners . great stuff around the edges then if you have some sag you can use the metal studs as supports . while in there make sure water tanks are secure .
northstar1960 is offline   Reply With Quote
Old 09-14-2016, 07:09 PM   #3
SilhouettePenny's Avatar
You mean the "un-sealed" underbelly. The only answer is more fasteners, learning how to drill holes in steel upside down and eye protection. Find the largest diameter stainless steel washers you can find and something soft to lay on.
Mine was so saggy I had to completely remove it from one end and reattach properly. It helps you get up close and personal with your best camping buddy!
1999 F250 w/7.3L Diesel
2014 Silhouette 299RKDS
Nights Camped 2016 - 21
He who dies with the most tools, wins!
SilhouettePenny is online now   Reply With Quote
underbelly
