Old 01-23-2016, 12:03 PM   #1
Upgrade windows
During the "snowmageddon" here on the east coast, I decided to use my RV in the driveway as an emergency shelter. So, when our family went out there last night (just to test it out), I noticed the windows have a draft. There is no obvious gap in the seals (this is a 2015 356QBQ 5th wheel unit) The glass is single pane.
So, I was wondering if there is a simple and cheap way that looks good that I could upgrade my windows for the future so the coach is better insulated?. I am sure most of the heat loss is coming from the windows. Any ideas?
MOODMAN is offline   Reply With Quote
Old 01-23-2016, 12:06 PM   #2
I have read where some folks have used the plastic sheets you can use a hair dryer on that tightens up, can not remember what they are called. we went with the dual pane on our Cedar Creek and very happy we did.
dblr is offline   Reply With Quote
Old 01-23-2016, 06:29 PM   #3
We are going this weekend and temps have been in the upper twenties for the last two days. We have three electric heaters running with the main furnace coming once per hour. Our next unit will definitely have dual pane windows and upgraded insulation. These fivers don't hold heat well and feel drafty.
Our camping neighbor has a class A DP and isn't having any troubles with drafts and is only using his furnace.
Sierra360PDEK is offline   Reply With Quote
Old 01-23-2016, 07:07 PM   #4
I wonder what the cost would be to install dual pane windows in a camper you have already brought
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 01-23-2016, 09:12 PM   #5
arpipeliner's Avatar
5K was what I was told
arpipeliner is offline   Reply With Quote
Old 01-24-2016, 03:00 AM   #6
Fulltime family RVer
I wondered the same thing. Our windows are a huge source of heat transfer. I hate it.
Youch. Ok, maybe my next camper will have them...
ependydad is online now   Reply With Quote
Old 01-24-2016, 07:45 AM   #7
I thought some camper Windows have a vent hole stamped into the aluminum frame at the bottom to allow for ventilation. I know my 2014 Coachman has them. So tempting to put some black RTV over those slots to seal it up.
bheston is offline   Reply With Quote
Old 01-24-2016, 07:52 AM   #8
Who Dares, Wins
doc73's Avatar
As far as the shrink wrap plastic I have sen this recommended on the RV windows as well to help seal things up, but you need a window that has a flange or whatever it is called to make the seal after the wrap is double sided taped to the wall. My windows are flush with the wall so it would not work.
I have also wondered the double pane windows but they seem to be another controversial topic of whether they actually make a difference compared to the junk insulation through out the rest of the trailer.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 01-25-2016, 03:19 PM   #9
If you are talking about the holes at the bottom of the exterior of the frames, those are for drainage.
Brewhedd is offline   Reply With Quote
Old 01-25-2016, 07:35 PM   #10
We just got a Sunseeker 2290S and went camping in 10 degree lows. We nearly froze our butts off. The cold comes right through those single pane windows. I found this stuff on Amazon and cut it so it fits snug in the window opening and it really helps to keep the heat in.
mtnbronco is offline   Reply With Quote
upgrade
