Old 03-30-2016, 09:12 PM   #31
Golfnbike13's Avatar
I've heard various claims about taking pressure up to 80ish, some are for and some against. Is there anything out from the manufacturers suggesting an appropriate pressure amount?
Golfnbike13 is offline   Reply With Quote
Old 03-31-2016, 04:02 AM   #32
Witch Doctor's Avatar
It would be very rare that you would find a CG with that much pressure to begin with, I always test the pressure with a rain bird meter. I have an adjustable watts regulator. But I had a leak running water at 55 lbs PSI. It's not the plex line that go's it's at the hose fittings where it comes in at with the cheap clamps they use to split off to the plex lines. I had a water leak the last time I was out. It was hard to find, found out the cheap clamp came loose and I couldn't tighten it up it kept slipping. So I replaced all the clamp areas with new S/S clamps. Easy to do but hard to get to. I also dropped my regulator down to 45 PSI, so far so good, the lines can hold the pressure but the fittings can't. Also the fixtures are cheap plastic held together with "O" rings. I heard of one guy that blew his faucets right off from to much pressure. He switched out to the household type from HD. I have never read anything from the manufacturer, but my dealer told me 45 psi. I think between 45 and 50 lbs would be max, without doing some bullet proofing.
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-31-2016, 04:26 AM   #33
crunchman12001's Avatar
Originally Posted by mjones12 View Post
They are great. Feels like it doubled the pressure in our shower. Amazing difference.
I took some miserable showers before I got Oxygenics. Best accessory I have bought.
X2, buy it. You will love it, I love mine.
crunchman
2015 F-250 FX4
Old 04-03-2016, 10:23 AM   #34
I did buy it, waiting to put it in now. Went camping 2 weeks ago 70° now 20 and 3" of snow today... Got to love ohio!!
Rayax23 is offline   Reply With Quote
Old 04-03-2016, 10:41 AM   #35
ferguson65's Avatar
Originally Posted by BamaBob View Post
And set your PSI to a reasonable 80-85 PSI and you will have residential quality showers in your RV!
Where in this country do home water pressures run at 80 PSI? Every home I've seen including the one I live in the well pump is set to 45-50 psi. Showers are just fine. Camper water pressure regulator is set to 45 psi also with no issues. Buy a good adjustable water pressure regulator, not the cheap inline non-adjustable thing, set to 45 PSI with the Oxygenics head and you should be happy. I am.
Cranking the pressure to double that is asking for headaches.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 04-04-2016, 02:09 PM   #36
City water PSI is 100lbs+ in certain areas of the little town I live outside of. Homeowners are responsible for installing their own regulators.
Humteddy2
2014 Silverado LTZ 1500
2016 Surveyor 285IKDS
Humteddy
2017 Surveyor 285 IKDS
2016 GMC Sierra Denali HD 2500 Duramax
Humteddy2 is offline   Reply With Quote
Old 04-04-2016, 09:04 PM   #37
Humteddy2
X2
Old 04-05-2016, 12:57 PM   #38
Home water pressure
[QUOTE=ferguson65;1151049]Where in this country do home water pressures run at 80 PSI?
The pressure at my house measures @ 80psi. Local water authority upgraded to this pressure some years ago.
Our water is piped from Lake Ontario.
CNYCamper is offline   Reply With Quote
Old 04-05-2016, 01:50 PM   #39
NW Pa
Humteddy2
2014 Silverado Z71 LTZ 1500
2017 Surveyor 285IKDS
Humteddy
Old 04-05-2016, 01:59 PM   #40
leefl's Avatar
I believe that most manufacturers rate the camper pipework at 60psi (tho' I've been told that they usually pressure-test at 80psi).
I usually run our pressure at 55psi (with a Watts regulator, which I'd thoroughly recommend) - I ordered the 263A-LF from rvwaterfilterstore.com ).
We also have an Oxygenics shower head which I bought from Amazon last year and it's a LOT better than the factory shower head.
Just in-case anyone is interested, I bought the Watts 263A-LF pressure regulator (which has much better flow than any of those little cheap inline pressure regulators) from RVwaterfilterstore.com (great service), and attach it to the water inlet (with a 90deg elbow to reduce the pull on the inlet), though I am thinking about mounting it inside the basement.
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
show, shower
