As odd as it may seem, sometimes RV absorption type refrigerators do have problems cooling when it's cold outside. They rely on natural draft through the heating chimney to change the phase of the cooling fluids. When the outside air is really cold, sometimes there's too much air going through the chimney and the heater (propane or electric) can't heat the airflow enough. If you have trouble, block off part of the refrigerator lower vent with cardboard to reduce the air flow.
I had one really strange problem with ours. I was preparing it for a trip in 20 degree weather. I started the refrigerator and it quickly brought the freezer below 15 F. I put water in the ice trays to freeze overnight. Since it was late I waited until the next day to dewinterize the water system and I didn't turn the heat on. The next morning the freezer was 32 F and there was only a skim of ice in the trays. With the coach so cold, the thermostat in the lower section didn't call for cooling, and the relatively warm water in the ice trays warmed up the freezer. I turned on the furnace, left the lower door open, and it began working fine.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
