Old 10-15-2016, 04:18 PM   #1
Vaccum break valve 36ckts location
I have a 2016 CC 36 ckts. When i hooked up to it last week to leave for MD, a significant stream of water leaked out from under the cabinet directly across from the entrance door. It is the floor to ceiling cabinet that houses the control panel and breaker distribution panel. Everything stayed dry during the trip including the last day which was rainy from Mathew, so I am fairly confident it is not coming from the roof or plumbing vent. Since this cabinet is directly behind the toilet, my only other guess is the vaccum break valve in the black flush line was leaking when I flushed at the end of the previous trip. My problem is that I can't find the valve. Does anyone know where it is located and / or how to access it? Thanks in advance.
mgas is offline   Reply With Quote
Old 10-15-2016, 04:50 PM   #2
BandJCarm's Avatar
No. But my 36CKTS is in the shop for warranty work for a complete and total compromise of the entire black tank system. Right now, it's dropped and on the ground as they try to find the source of the problem.
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 10-15-2016, 05:00 PM   #3
That's no good. I hope your luck changes and they solve your problem. My leak was or is a clean water leak, but I would be interested in hearing how your issue gets resolved.
cat, location, valve
