Old 11-05-2014, 01:06 PM   #1
Valve to water tank
New 2015 Windjammer 3008w owner. Getting ready to winterize using the winterizing outlet. It says close the valve to the tank and open valve to inlet. Where are these located. Are there any pictures available to look at? Thanks Cyndi
CLewis is offline   Reply With Quote
Old 11-05-2014, 01:25 PM   #2
joy-rick's Avatar
In my TT they are located in the same compartment as the water pump.
Rick (K8RWG), Joy, and Daffy (the spoiled Calico cat)
2014 Rockwood 8315BSS
2016 F250 SC LWB 4x4 6.2 3.73
Reese Dual Cam
Honda EU2000i
joy-rick is offline   Reply With Quote
Old 11-05-2014, 01:26 PM   #3
mTn_biKer65's Avatar
If there's one installed it should be near the water pump. If you're not sure where that is turn it on and follow your ears, you'll likely need to lift a seat or remove a panel to access it. Once there you'll hopefully see a "T" junction on the water line near the pump with about a 3' piece of hose hanging off of it. Lots of good write-ups here about best practices for winterizing.
Also, make sure you've bypassed your water heater and possibly your water filter if you have one before attempting to fill the system with anti freeze. Otherwise you'll end up wasting more than you need to.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 11-05-2014, 05:49 PM   #4
Does one valve close the tank and open the inlet or are there 2 separate valves?
Old 11-05-2014, 05:56 PM   #5
MtnGuy's Avatar
It is usually a 3 way valve. When the lever is parallel to the fresh water tank line, then the water comes from the tank. When the lever is parallel to the siphon hose, then it will siphon from a RV antifreeze bottle.
Old 11-05-2014, 06:14 PM   #6
Thanks. That makes sense.
tank, water, water tank
