Old 04-20-2016, 10:12 AM   #1
Velcro on Dinette Cushions?
Our bottom dinette cushions always move out of place after sitting on them. I noticed at the RV show this year that there were some new TTs that had strips of Velcro underneath the cushions. I want to use that on our seats but not sure what kind of Velcro to get. I looked at some the other day at Lowes that came in large strips and they all said not to use it on vinyl or fabric.
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
zinger60 is offline   Reply With Quote
Old 04-20-2016, 10:20 AM   #2
AquaMan's Avatar
That could be because of the adhesive (if they were self stick). You can get velcro for fabric/vinyl (not sure what your cushions are) at fabric stores or Walmart in the fabric section.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 04-20-2016, 10:21 AM   #3
RSchleder's Avatar
You probably need to remove the seat covers and use, or find, a heave duty sewing machine and sew them to the seat material. Chances are the "paste-on" type velcro does not stick to the material the seat bottoms made of!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 04-20-2016, 03:19 PM   #4
mjones12's Avatar
My Surveyor came with Velcro on the back support cushions, but not on the bottom cushions. It's more like a long, curved couch with 5 or 6 back support cushions, and the Velcro on them really does a good job.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 04-20-2016, 04:24 PM   #5
Is the Velcro just stuck on there? Not sewn on, correct?
2011 MicroLite 23LB
Old 04-20-2016, 04:47 PM   #6
Could not get Velcro to stay stuck on in our old Catalina TT. Used 1/2 carpet foam underlay instead and it worked well. Yoga mats also work - about 1/4" thick and are fairly inexpensive.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 04-20-2016, 05:00 PM   #7
spierce617's Avatar
I just put some of that material down that we use in the cupboards to keep the dishes from sliding around. Works like a charm and keeps the cushions in place.
2005 Winnebago Adventurer 38R
Workhorse 8.1/Allison Transmission
Old 2005 Forest River Cherokee Lite 28A
spierce617 is offline   Reply With Quote
Old 04-21-2016, 08:03 AM   #8
MtnGuy's Avatar
That is what I did. I got an upholsterer to sew the Velcro unto the fabric.
Old 04-21-2016, 11:46 AM   #9
Dahagen
Here is the perfect Velcro....#91227. It is industrial strength and comes in a roll 15ft by 2-inches. It sticks great (over a year) to both the seat cushion and the wood platform. I cut a strip about 2/3 of the length of the seat. Seat does not slide!
dahagen is offline   Reply With Quote
Old 04-21-2016, 12:59 PM   #10
mdstudey's Avatar
I am going to have to give that a try.
For those using velcro, you will want to sew it on to the bottom of the cushion over. If you used the stick on on that part and wanted to wash the cover, it would make quite a mess especially if you were to throw it into the dryer. You really would not need an industrial machine, but be sure to use the correct needle. If you don't sew, an upholster shop would be able to do it. I don't imagine they would charge to much.
Chuck & Denise + Pata, The Purple Princess Peanut, Ziggy the pole cat and Kazumba the parrot
2015 23 BD Gray Wolf
2008 Dodge Ram 2500 TX Edition 2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights 2018 1 trip, 93 nights
mdstudey is offline   Reply With Quote
Old 04-21-2016, 01:25 PM   #11
I tried the industrial strength velcro at first and it would not stick - period. It was like the plywood (faux wood finish) has a coating of teflon on it. Even tried several types of glue to no avail. The stuff isn't exactly cheap - maybe it's worth testing first to see if anything sticks.
Langley, BC
Old 04-21-2016, 04:01 PM   #12
Delco Bobby's Avatar
I did two things with velcro to solve my sliding cushion problem.
I noticed that the velcro on the cushions did not line up with the velcro on the bench backs. I put longer strips of velcro on the bench backs to get them to attach to the cushions.
I also had a long roll of velcro that I used many years ago to keep carpet runners from sliding onto of a carpet in a commercial application. I laid down two strips of this velcro on each bench top to add some friction. There was no corresponding velcro on the cushion bottom.
My cushions no longer slide and it was an easy fix.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 04-21-2016, 04:11 PM   #13
mjones12's Avatar
Mine is sewn on....from the factory.
Old 04-21-2016, 06:01 PM   #14
On my Sunseeker the velcro was sewn onto the cushions but was were worn and did not match up well with the buttons on the wood bench backs. the velcro button and the velcro strip did not touch.
Putting longer strips on the benches solved that problem and the worn velcro seems to hold OK.
2018 Ford F-150
Old 04-21-2016, 09:44 PM   #15
Camper
Tracer215AIR's Avatar
Lowes Valcro and Superglue.
Lowes has the stuff : HERE
and plain old super glue worked for us. no more sliding...
2013 PrimeTime Tracer 215AIR Touring Edition
2014 GMC Sierra 1500 Z71 6.0l
Nights Camping: 2013 - 15; 2014 - 25; 2015 - 35
2016 - 5
Tracer215AIR is offline   Reply With Quote
Old 04-23-2016, 07:24 PM   #16
Worked for me.
pdqparalegal1 is offline   Reply With Quote
Old 04-23-2016, 08:43 PM   #17
Originally Posted by pdqparalegal1 View Post
Worked for me.
For me that stuff was an improvement but the cushions still moved until I switched to the Velcro.
2018 Ford F-150
