Old 09-12-2014, 06:29 AM   #21
Great point - thanks! May even do a 50 amp plug since I already have a 50 to 30 pigtail.
Brian, Stacy, and the girls (11 and 8)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 08-12-2015, 08:13 AM   #22
Long delay on updating this thread. We did put up the AllSteel building last fall. See first picture. Building is 18 x 40 with 12' side walls. Had it built with three full walls and the parts for a fourth wall (used this material to build the doors mentioned below).
More recently, over the last 2 weeks, I finally got around to adding power and compressed air (second pic). Also got a good start on the front doors (last 2 pics). They are designed to preserve the full height of the opening 14'2" at the center) whereas a traditional overhead door would have take clearance down to 11'.
Still some work to do reinstalling front trim, installing top panels on doors, cleaning up the cutoff saw dust.
Hopefully this info will be helpful for anyone else contemplating a building like this.
Thanks to all for your input and advice.
ID:	85397   Click image for larger version
ID:	85398   Click image for larger version
ID:	85399   Click image for larger version
ProPride Hitch
Old 08-12-2015, 02:34 PM   #23
panthercity's Avatar
And thank you for the follow up!
Certified JB Welder. Certified 3M Duct Tape installer.
Certified Farmer's Co-Op bailing wire expert. Graduate of the "Rock on the side of the Trail as a Hammer" school of motorcycle repair.
Getting old is just a matter of narrowly missing all the things that kill you.
panthercity is offline   Reply With Quote
storage
