Old 05-16-2011, 05:57 AM   #11
dretired's Avatar
warm,then cool water ??
so should the middle valve be closed ??? Its mid way between the top and bottom of the tank on a vertical water line
dretired is offline   Reply With Quote
Old 05-16-2011, 06:09 AM   #12
grhodes50's Avatar
Yes. That is your bypass valve. Left open (handle in line with water line) will allow the cold water to mix with the hot. Results will be warm/cool water instead of hot.
Good luck and happy camping.
Gary & Trish
2018 Nights Camped - 5
Old 05-31-2011, 09:41 PM   #13
cebaker's Avatar
I have a 32vbhs vcross and I can't find the bypass valve. my water heater gets hot but out of the faucet and shower it's luke warm. Can anybody tell me?
2010 Toyota Tundra
Forest River 32vbhs
cebaker is offline   Reply With Quote
Old 06-01-2011, 05:09 AM   #14
dretired's Avatar
cebaker, find the panel inside that would be at the heater from the inside, mine is under the sink. close the valve that is vertical between the top and botom of the tank.
Old 06-01-2011, 08:44 AM   #15
cebaker's Avatar
Thanks, I will look when I get a chance. I'll let you know.
2010 Toyota Tundra
Forest River 32vbhs
Old 06-19-2011, 05:54 PM   #16
cebaker's Avatar
Dretired, I find the bypass valve this past weekend. It was one little screw that was hidden near floor to open the panel. Just wanted to let you know.
2010 Toyota Tundra
Forest River 32vbhs
