05-15-2011, 10:25 AM
Warm ,then cool water
I am getting warm then cool water, from the hot water valve on the kitchen sink, i have the pump on when this happens, do i need to shut some bypass valve below ??
05-15-2011, 10:30 AM
Sounds like your by-pass valve is on. Check by the water heater for the valve. I'm sure that you can get a better answer from someone here if you include the year and model of your camper.
Good Luck!
Tom and Margaret
2014 Berkshire 390bh-60
05-15-2011, 10:36 AM
warm ,then cool water
Its a 2010 puma palamino 26rlss, propane only water heater..
05-15-2011, 12:09 PM
I had the same thing with our first trailer - Bypass was open allowing the cold and hot water to mix. Any bypass I have seen has always been at the back of the water heater in between the cold intake (bottom) and the hot outlet (top)
05-15-2011, 02:05 PM
warm then cold water from heater
I have got to look at the water lines and see whats going on down there.. its too bad they dont have a diagram on the acess door explaining things for the owners !!
05-15-2011, 02:11 PM
are you sure your WH doesn't also have electric heating?
i'm pretty sure yours should, check for a switch on the WH itself, from the outside access.
do you know what brand WH it has?
05-15-2011, 02:18 PM
suburban water heater ..NO outside switch..
05-15-2011, 03:16 PM
can you take a picture of your water heater with the door open so we can see what model you have then to give you better info
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
05-15-2011, 03:28 PM
warm then cool water from water heater
I will try and get a few pics on this site tommorrow
05-15-2011, 09:55 PM
What you will normally see is two valves just before the entry to the tank - those should be open except when winterizing. Then another one that joins the two lines - that one should be closed except for winter. The following post has a picture of what you might see.
http://www.forestriverforums.com/for...alve-9031.html
05-16-2011, 05:57 AM
warm,then cool water ??
so should the middle valve be closed ??? Its mid way between the top and bottom of the tank on a vertical water line
05-16-2011, 06:09 AM
Yes. That is your bypass valve. Left open (handle in line with water line) will allow the cold water to mix with the hot. Results will be warm/cool water instead of hot.
Good luck and happy camping.
05-31-2011, 09:41 PM
I have a 32vbhs vcross and I can't find the bypass valve. my water heater gets hot but out of the faucet and shower it's luke warm. Can anybody tell me?
2010 Toyota Tundra
Forest River 32vbhs
06-01-2011, 05:09 AM
cebaker, find the panel inside that would be at the heater from the inside, mine is under the sink. close the valve that is vertical between the top and botom of the tank.
06-01-2011, 08:44 AM
Thanks, I will look when I get a chance. I'll let you know.
2010 Toyota Tundra
Forest River 32vbhs
06-19-2011, 05:54 PM
Dretired, I find the bypass valve this past weekend. It was one little screw that was hidden near floor to open the panel. Just wanted to let you know.
2010 Toyota Tundra
Forest River 32vbhs
