Old 09-05-2015, 12:49 PM   #1
crunchman12001's Avatar
Warning: Airwick oil plug in melted counter top
Just a warning to all.
We used a Airwick scented oil plug in for the bathroom. I had heard of these catching fire so we always unplug it while we are not at the trailer. The airwick was laid on it's side on the bathroom counter and the oil must have leaked out. There must be something nasty in the oil because it ate through the counter and bubbled the laminate. The oil was trapped under the laminate and turned it to jelly. I cut the bad spot off to get the oil soaked up. My trailer is a 2011 so I am sure I will never find a replacement top to match. Any ideas to fix it?
Here are 3 pics
ID:	87854   Click image for larger version
ID:	87855   Click image for larger version
2015 F-250 FX4
Old 09-05-2015, 12:58 PM   #2
Done with this
That sucks!! I left a can of Off in our first pop up. The bottom busted and the Off ate a trench all the way across the linoleum where it ran and sat. Had to replace the whole floor.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 09-05-2015, 01:02 PM   #3
f5moab's Avatar
Good to know. Looks like some nasty stuff.
f5moab is offline   Reply With Quote
Old 09-05-2015, 01:03 PM   #4
That's what stinks, just like these airwicks, who would think Off would ruin a surface?
Thanks for the heads up.
crunchman
2015 F-250 FX4
Old 09-05-2015, 01:12 PM   #5
Who Dares, Wins
doc73's Avatar
crunchman
And imagine.. You put the off on your body...
Heard rubbing alcohol will hurt the counter and floor as well.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 09-05-2015, 03:26 PM   #6
Twistedpairs's Avatar
You could do what we did (minus the counter damage) stick a hand soap dispenser or dish with double sided tape over the spot, no need to resurface. Either that or apply filler, sand, and get some faux granite countertop paint from Home Depot. Cheaper and lighter than granite that's for sure!
Twistedpairs is offline   Reply With Quote
Old 09-06-2015, 02:29 PM   #7
bthaler's Avatar
We replaced the counter in our outdoor kitchen with cultured marble. Turned out really well. Won't swell up. Your small counter shouldn't cost a lot. Good luck.
bthaler is offline   Reply With Quote
Old 09-06-2015, 02:49 PM   #8
We had the same thing happen to our Chrysler van. Hung the liquid filled air freshener on the heat vents. Eventually it sprung a leak, ran over the heater and a/c controls, and melted some of the buttons together or in or out. Disfigured the control panel. Took it to dealer, 350 bucks to fix it. Took a razor blade to the cracks between the buttons to cut spilled liquid. Everything now works, looks like hell, but it isn't my new truck
pacin is offline   Reply With Quote
Old 09-06-2015, 02:51 PM   #9
Plain Old Member
I'd just look at it as an opportunity to put a really nice countertop of your choice in there. It stinks that it happened, but we always try to use mishaps as opportunities for improvement.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 09-06-2015, 03:07 PM   #10
DDC
DDC's Avatar
I read somewhere that those things are the leading cause of home fires.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
