Old 10-09-2014, 08:11 AM   #1
wash & wax
So as a new TT owner I'm wondering what everyone uses to clean and wax their aluminum sided trailer and rubber roof.
I hear Wesleys bleah brite works good on awning & dawn dish soap for the roof with a mop.
Any feedback?
grumpyer is offline   Reply With Quote
Old 10-09-2014, 08:17 AM   #2
mud yapster's Avatar
After cleaning then protect it all with 303 Aerospace Protectant, from your awning to pin stripes to roof and tires with 303 protectant. You can get it by the gallon from Amozon for $45, check it out.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 10-09-2014, 08:18 AM   #3
WFD
Also if you do a search in the forums here, the topic has been discussed a ton...you will surely find lots to read.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-09-2014, 08:21 AM   #4
If using 303 on aluminum siding do I still need to wax?
Old 10-09-2014, 08:42 AM   #5
WFD
303 is a great UV protectant and is great on decals because wax will dry out your decals, and many will tell you to avoid wax on decals. However 303 is not a wax and will not cause water to bead up like a wax does, and make for easier washing as wax does. I prefer to use a wax product on the trailer and use 303 on decals.
Old 10-09-2014, 08:45 AM   #6
Flagstaffer06's Avatar
X2 on the using a wax but, 303 on the decals. It's sometimes a little tough to steer around the decals but, manageable. I use NuFinish on the trailer and it's easy to put on and off. I just don't put it on the decals, I use 303 on those.
Do a quick search as WFD said, you'll find tons of opinions and options.
2012 Keystone Sprinter
Still sticking around for the good people and advice.
Flagstaffer06 is offline   Reply With Quote
Old 10-17-2014, 09:10 AM   #7
I went to the roof manufacturers website they said use household detergent that does "NOT "contain citrus or petroleum products . I use the original Dawn .
jerry1946 is offline   Reply With Quote
Old 10-17-2014, 09:12 AM   #8
I use a good car wash &. Wax product for sides.
Old 10-17-2014, 12:28 PM   #9
Dealer suggested to just wash with car wash such as RainX since there is a gel coat on the new camper. We did it this way all year. In the past we had used a dry polish that you apply and then wipe off. It allowed for water to bead and gave it a good shine. Could also be used on windows. It was not purchased from a store but from a person who sells the material. Since that person is not around anymore, I can't help you with the name of product.
wiscoheel is offline   Reply With Quote
wax
