Old 02-26-2015, 07:39 PM   #11
Blackhat6mike's Avatar
Roos
You might want to check out this site to see if you are effected.
http://www-odi.nhtsa.dot.gov/owners/...tsa_ids=15V080
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 03-06-2015, 03:07 PM   #12
Not sure what you mean when you say there is condensation? Never had a problem with my internal water filter, start of each camping season I check the plumbers tape on the connections, make sure everything is tight. I guess with the picture above it would add a couple of minutes to the set up time as they are easily avail connectors. This is the first I have heard of water problems from the city connection.
Kevin
tenttotrailer is offline   Reply With Quote
water, water filter
