Old 03-24-2012, 10:54 PM   #1
Athens-M50's Avatar
Water filter...flooded again.....
for the love of all that is good!!!!!
EVERY time I change the water filer I flood the camper.......it take about 3 times taking it off and back on....before I get it to not flood.......ERRRRRRRRRR
soooooo frustrating!
any tips?
2002 17' Shamrock
2001 F150 Ext Cab
________________
2012 nights camped 6
Athens-M50 is offline   Reply With Quote
Old 03-24-2012, 11:09 PM   #2
Bill_C's Avatar
any tips?
Take the whole filter system out of the camper. Hook it up outside in line with the water source and the camper water inlet.
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
Bill_C is offline   Reply With Quote
Old 03-24-2012, 11:11 PM   #3
sherdep's Avatar
The clear canister should screw pretty easy until it hits the top - is yours hard to turn?
check the seal or put a small amount of vasaline on the rubber O ring
Does your filter have a top and bottom seal as well as a O Ring seal for the canister?
If not I know WalMart sells a whole house filter canister (same as in my trailer) maybe replace the filter housing and canister with a new style
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 03-24-2012, 11:31 PM   #4
Athens-M50's Avatar
it is....it's the small filter about 5".....rubber washer on top and bottom......clear canister......
I think it's when I am screwing it on....it is not getting square on the top side......and not letting it seat when screwing it on.
pisses me off when I got water running everywhere!
2002 17' Shamrock
2001 F150 Ext Cab
________________
Old 03-24-2012, 11:32 PM   #5
Athens-M50's Avatar
leaving in the morning going to Fall Creek Falls in TN.
that makes it better!!!
2002 17' Shamrock
2001 F150 Ext Cab
________________
Old 03-24-2012, 11:39 PM   #6
sherdep's Avatar
I have the filter housing inside the camper and I also camp with one on the outside so I have a dual filter system going on.
I usually give it a slight shake on the canister to see if the filter moves and helps seat the filter. filter and seal are seated in the clear canister and then screw it up to the housing.
Have a safe trip
Old 03-25-2012, 04:21 AM   #7
Mountainmanbob's Avatar
plumbers valve grease
you should not have to mess with it too often
but
when you do
put a pan under filter
turn water on low
if it starts dripping
run and turn water off
or
have somebody at the hose bib
I put plumbers valve grease on mine
makes all moving water parts
go together so much better
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 03-25-2012, 07:13 AM   #8
Oakman's Avatar
You mentioned the rubber washer top and bottom on the filter, but as sherdep mentioned, does the clear canister still have the rubber O ring in the top of the canister. The loss of that O ring is usually the cause of leaks at the filter.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 03-25-2012, 09:16 AM   #9
Athens-M50's Avatar
yes...it does have the O ring......
2002 17' Shamrock
2001 F150 Ext Cab
________________
Old 03-25-2012, 09:53 AM   #10
valve grease -- put on O-ring and threads
buy some valve grease (local hardware store)
screw that THING in and out at least a few times
you will get the feel of it (when it is tight)
the filter in our home under the sink
gave me a leaking problem
until I greased it up good
and screwed it in and out four or five times
from many years of doing water repairs for the City
can't live without valve grease
led pad
