Water Flow through TT Plumbing System
Time to de-winterize my 2017 Flagstaff 25KS. This will be my first time doing so. Had a question about the water flow. When I winterized I pushed the antifreeze from the external antifreeze fill valve through the water pump to all faucets. Of course, that left antifreeze in the fill hose, the water pump, the filter and all lines.
Please confirm the following is correct: after draining antifreeze through the low point drains I must initially flush the residual antifreeze from the lines before and after pump and from filter canister by running some water from the fresh water tank. This will clear the lines (and pump and canister) that are otherwise bypassed when using the city water connection. Once clear water is flowing through the pump, canister and all faucets I can continue to clean the lines out and fill the water heater by using water from the city connection.
This newbie thanks you for your guidance.
