Old 06-02-2016, 01:17 PM   #1
water from water tank
need help! I am leaving tomorrow morning for the Nascar races and have for the very first time filled up the on board water supply tank. I can hear the water pump when turned on, however, no water at all not even a drip. I am sure that I am missing a step...please let me know and thanks in advance
Bigairh20 is offline   Reply With Quote
Old 06-02-2016, 01:35 PM   #2
Mr. Dan's Avatar
Incorrect valve settings, probably. Sometimes people leave open the valve to the line through which antifreeze is sucked for winterizing and the pump only sucks air. Sometimes the water heater winterizing valves are in the wrong position.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 06-02-2016, 01:36 PM   #3
Prime Member
If it's your hot water, it will take a few minutes for the hot water tank to fill when you turn on the hot water for the first time.
Important: Make sure your water heater is full before turning on the water heater switch or you can damage the heating element.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
Old 06-02-2016, 01:39 PM   #4
Mr Dan you are the man. Exactly what it was
tank, water, water tank
