Old 01-27-2015, 10:04 PM   #1
Water heater
I'm trying to get my water heater to work. I had drained the water for winter. I flushed out the air and turned the elec. back on for the heater. Nothing! I changed the anode rod, but still nothing.
I'm now trying with the propane and it is heating.
The electrical switch doesn't throw a breaker and all other electrical items work.
Any suggestions?
Larry Tiner is offline   Reply With Quote
Old 01-27-2015, 10:10 PM   #2
Platokidd's Avatar
I had this problem last year. I went outside to heater access and wiggled the wires. For me it worked.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 01-27-2015, 10:11 PM   #3
wmtire's Avatar
Did you make sure there was water inside the heater before turning on the electric heating element switch? If not, then you may have burned it up.
Also, any chance when you winterized, you may have also turned off the breaker to the electric heating element inside the breaker box.......or possibly unplugged it from the electrical outlet behind the heater and forgot about it?
And I know this may seem obvious, but you are plugged into a form of 120 volt shore power in order for the electric heating element to work since you stated other electrical items work which I assume you mean 120 volt stuff (television, microwave, electrical outlets)?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 01-28-2015, 09:23 PM   #4
I wiggled the wires, but got nothing. Replaced the heating element --- Bingo! Thanks for y'all's help!
Old 01-28-2015, 09:53 PM   #5
Flybob's Avatar
Be sure to turn off electric WH switch each time you break camp. That way if you plug in the RV to clean or prep for a trip, you do not apply power to the WH while it may be empty.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-29-2015, 04:21 AM   #6
Have to remember that, FlyBob. Thanks!
Old 01-29-2015, 06:45 AM   #7
wmtire's Avatar
If you don't use checklists, then an easy way to remind yourself if you have a trailer.... is to take a clothespin and write water heater on it with a sharpie.
Whenever you turn on the electric switch, snap the clothespin on your trailer coupler. This way you can't hook up to your TV, without seeing the clothespin to remind you to turn off the switch.
You can also do clothespins for other things, like antenna, awning, steps, etc.
Or if that's just too low tech, you can buy these at this link:
http://www.rvminders.com/
Old 01-29-2015, 06:53 AM   #8
Dave Lyon's Avatar
FWIW, I only drain my water heater once a year; and that is when I winterize. Even if I left the switch on - the tank is full of water.
It is still a good practice to turn the switch off when packing up camp (which I do), but, at least with water in your heater, you won't burn out the element if the switch is left on.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is online now   Reply With Quote
Old 01-29-2015, 06:54 AM   #9
Dave Lyon's Avatar
Sorry- I should add to this, I'm on chlorinated City water, not well.
Dave, Southern,ON
heater, water, water heater
