Old 10-01-2016, 01:16 PM   #21
leave the water on it will only run when needed
gickes is offline   Reply With Quote
Old 10-01-2016, 01:31 PM   #22
Originally Posted by Cigarman View Post
Same here. I turn it on and leave it on. I like the convenience and would probably forget to turn it on until right before I needed it.
X2
Thanks for asking the question, cuz I did wonder what others thought was best.
brewjaz is offline   Reply With Quote
Old 10-01-2016, 04:15 PM   #23
We have a 2012 Rockwood MiniLite #2304. When we're on shore
power the hot water tank is on all the time on electric. However
after about 4 or 5 days I've noticed there will be no hot water.
Have to turn the switch off, wait 10 seconds & turn it back on &
away it goes.
Ian Walker is offline   Reply With Quote
Old 10-01-2016, 05:33 PM   #24
Originally Posted by dukeboone View Post
If I'm on hookups I leave the water heater on (unless I turn the water supply off, which I do when I leave for an extended period). If I'm dry camping I leave the water heater off until I need it, it seems to heat really fast on propane, and I really don't need it to maintain the hot water all day long.
X2
mtnlvr is offline   Reply With Quote
Old 10-02-2016, 07:30 AM   #25
Originally Posted by NMWildcat View Post
Zowie... Another item to add to my list of RV subjects that folks over think We never turned ours off when we had a tank, and we always ran propane and electric at the same time. Now we have tankless, non-issue😁
I always left mine on. I was just curious if I wasn't supposed to as I hadn't heard or read anything about it. There have been a few things I was surprised to find out.
2017 Cherokee Grey Wolf Limited 26BH
kantonburg is offline   Reply With Quote
Old 10-02-2016, 07:38 AM   #26
When we camp, it is always on. When we get home from a trip, the wh is turned off, anode removed/re taped and loosely installed to keep varmints out and pressure relief valve is opened to drain. Been doing it like this for years with no problems.
Old 10-02-2016, 08:14 AM   #27
I was going to say that I do the same as the old man but then it occured to me that I AM the old man!
Since mine is propane only I keep it off until needed.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 10-02-2016, 08:52 AM   #28
I figure 11 years is good life from the water heater. Yea, i just replaced mine after 11 years. When I have had it on gas, once hot it only comes on maybe 4 times a day for a few minutes to maintain water temps. Guess Im used to being at home with plentymof hot water.
donniedu is offline   Reply With Quote
Old 10-02-2016, 09:03 AM   #29
Canadian Member
I've been experimenting with turning it off if we leave for the day on an excursion and when we go to bed at night. I've found that our tank is well insulated and the water stays reasonably warm if the heater is off for 8 hours. Not hot, but more than room temp. So I really don't think it uses much propane if you leave it on without a water demand.
Old 10-02-2016, 09:07 AM   #30
Insert witty title here
Water heater - Always on or only when needed?
When I first bought my camper, I took it on a 1400 mile drive to Orlando. I left the water heater on propane the entire drive down and it emptied one of my propane tanks. Ever since, I leave it off until about 15 minutes before I want hot water.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 10-02-2016, 09:11 AM   #31
That's one heck of a lot of propane. Are you sure the tank was actually full when you left?
2011 Traverse LT, 3.6L, FWD
Old 10-02-2016, 09:15 AM   #32
NMWildcat's Avatar
I am fairly sure posters are talking about turning WH on/off once you are set up at a campground. I don't know of anyone that travels with a TT or 5'r and has the WH turned on while on the road.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
NMWildcat is online now   Reply With Quote
Old 10-02-2016, 09:24 AM   #33
NMWildcat's Avatar
After thinking about this more, one of our first 5'rs had an exceptionally loud WH that was close to the bedroom. We did turn that one off at night so it wouldn't wake us up every time it kicked on. OP, I'm sure after using your rig for awhile you will decide what works best for you when it comes to managing your hot water
Old 10-02-2016, 09:34 AM   #34
I was new to the whole RV things so I will chock this up as a newbie mistake.
Now that you mention it, I doubt the tank was full. This was our first trip with it after bringing it home from the dealer so I have no way of knowing just how much was in there at the time.
Old 10-02-2016, 09:47 AM   #35
Wolverine 1945's Avatar
We run ours only on ele now that we are camping in State Parks,,, we turn it on about an hour before we need it,,, and off the evening before we leave,,, it is still pretty hot in the morning !!! We do not use any more propane that we have to,,, we use a hot plate so that we do not use the stove unless we have to,,, all meat is cooked on our little grill !!! Which does mean we must buy small tanks from time to time !!!
Wolverine 1945 is offline   Reply With Quote
Old 10-02-2016, 09:55 AM   #36
Yea we hardly ever use the stove, I cook outside. The hot water heater and the furnace in winter. We hardly ever turn our propane hot water on. We use campground electric for hot water
spock123 is offline   Reply With Quote
Old 10-02-2016, 10:03 AM   #37
Years ago we camped with friends in a park where they had shares,,, we only use ele,,, it was like free,,, we even used ele grills & ele fry pans outside !!!
Old 10-02-2016, 10:10 AM   #38
not to derail, but being in the US, you have the option to refill those small tanks from a 20 pound tank with an adapter (I purchased mine from Cabelas). I can refill for pennies, as opposed to buying new small green bottles for a couple of dollars. And every year, I will recycle my small green bottles and replace them with new ones that someone else just bought for the weekend trip....
Back to the OP's question though, if plugged into the campground power, the WH is on all the time. If dry camping, it depends on how much hot water we need. Can usually heat enough water for dishes on my Coleman stove while enjoying a beer and save on propane..... Although the Coleman fuel isn't getting any cheaper either.... Still looking for a cheaper alternative to that...
J.
jcrayford is offline   Reply With Quote
Old 10-02-2016, 10:31 AM   #39
I fill my water lines/water heater and put about 5-10 gal in fw tank, turn on frig and water heater before we leave for FL in Nov and it doesn't get turned off until we get home in late Feb, early Mar. It is on while on the road the entire trip to and from.
Old 10-02-2016, 11:00 AM   #40
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by raspivey View Post
I used to think that until I realized it was using more propane to heat it up between uses than just letting it maintain the heat.
I wondered the same thing. How did you "realize" that? What measurement or comparison led you to that conclusion? You can save me some time (and propane) if you figured this out with some measurements.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
heater, water, water heater
